BlueCruise 1.4 Road Trip Observations
KennyB123
Ken
Detroit, MI
2023 Lariat ER - I was lucky enough to get the update on the first day they started sending it out. I didn't get a chance to really test it until a few days ago on a 300 mile road trip between the Detroit area and the Indianapolis area.
Living north of Detroit, I took I-94 south to I-75, to the Ohio Turnpike where I had my only charge of the trip. Then eventually to I-69 south.
Here are some of my observations -
  1. On I-94 before the update, BC 1.0 would disconnect on EVERY curve, and even randomly if I drove in the left most lane with a yellow line on the left. On this trip, my mind was blown. Not a single disconnection through that entire segment, and the truck rarely even slowed down during those steep curves. (74mph)
  2. On all highways, lane changes were great. It actually takes stress away because I quickly learned to fully trust it's own blind spot monitoring before auto lane changing. I just clicked the blinker and let it happen. It takes anywhere from 7 to 9 turn signal activations to finish the lane change, and yes, the rear turn signal light does light up for all of them, even the 3 or so blinks that occur before it starts to move lanes.
  3. My first BC disconnection was when going through the EZ Pass fast lane camera area. After it did it on a second EZ Pass lane, I realized it was intended behavior. I'm not sure why, but it turned back on immediately.
  4. A couple lane change observations - on BC 1.0, if you touch the wheel to change lanes, BC would disconnect. Now, you can "assist" the lane change by beginning the lane change earlier than it would on its own. BC remains engaged and happy. One time, I accelerated ahead of a car while manually lane changing, hitting 81 mph, and BC still didn't skip a beat. Amazing.
  5. I had one emergency red box exclamation point moment when I only had a minor required deceleration, and yet BC remained engaged and happy after it was over in around 2 seconds.
  6. The feature where the truck can get over on the opposite edge of the lane when passing a large vehicle like a semi truck was hit or miss. But, when it worked, it brought a smile to my face. I think it might even get to the right edge of the lane when being passed on the left, which is great as well.
Overall, I basically traversed the entire trip with a fully functioning BlueCruise, and it was amazing. What an upgrade.
MrLoganRoss
Logan
Seattle Washington
Ah. Is there an OTA number to look out for? I do get OTA periodically but not sure which one relates to 1.4, unless it says 1.4 :)
I have a 24 and would have thought that would have been an easy and early roll out.
rugedraw
Javier
Miami
Auto Sales
Right now, it is only being sent out to 2023 model year trucks.
TheBigBezo
Earth
F-150 Lightning Lariat ER
I also did a recent road trip with 1.4 but most of it was the hands on variant. I noticed that the truck now gives you a heads up it's going to slow for an upcoming turn. Right above the speed limit I could see a turn icon. Flip side is the truck would brake laughably early (500-1000ft) prior to the turn and release braking prior to the apex. I actually disliked it enough to hand drive the winding road I was on. Even turns that were not particularly tight it would slow excessively early. If it was tuned to brake later it would be safer in my opinion I was worried about being rear ended.
Another observation is that it does handle lanes a lot better. When I was in hands free mode I had stiff 40mph winds perpendicular to me and the truck maintained it's line really well and even shifted for a large truck overtaking. The man ahead of me in a Silverado was getting pushed over the lane divider so consider me impressed.
Lane changes take forever, I fear that the delay before initiating a pass will confuse anyone behind me. 1.4 is a huge improvement but the timing on some of these features is off a bit. I couldn't use 1.0 in a winding road because it wouldn't slow at all and now 1.4 jumps on the brakes too early so the end result is I'm still not using driver assist in that scenario.
Many improvements but a few new added oddities.
astrand1
Alex
Studio truck driver
QQ: how did you confirm you have 1.4?
If you have the lane change assist and the in lane repositioning in your settings that’s one easy way to know that you have 1.4
astrand1
Alex
Studio truck driver
So how I’ve dealt with the early braking for a curve is when I see it or start to feel it I just roll lightly into the accelerator pedal just enough to to keep the speed I have and then once it seems like it’s past that point I let off. It’s something I’ve had to get used to but it works.
StevenC56
Steven
Fresno California
2024 Lightning Lariat Avalanche, 2017 Explorer Platinum
Has this been confirmed? My 2024 has those options, but I haven't received and BC update.
Mache_Enrique
Denver Co
'23 Lightning Lariet ER, '18 Subaru WRX STI, '25 BMW i5 (RIP 21 MachE GT)
Finance
2023 MY owner still dreaming of the 1.4 update showing up on his truck 😎.
