Yellow Buddy
- Feb 5, 2022
- Mid-Atlantic
- F-150L Pro, Rivian R1T, Model S, Model X
- Occupation
- Smart Ass
Correct, best if you put the truck up on the lift.Hi Yellow Buddy, so underneath the truck?
Typically stamped vin locations will be on the frame rail, the engine/trans, or the firewall.
Our firewall is covered up with reflective barriers, and we don't have an engine trans. I would personally put the truck up on a lift and inspect the motors for the VIN# and battery pack, but I'm not sure either would qualify as "Chasis" and they're likely not stamped.
The only location I think would actually be stamped would be the truck cab, which would be the window plate or the frame. I would check the frame rail and if that fails, I'd probably pull out the frunk tub to see if there's a stamping underneath there.
