Charging Faults since update in March 2025 post #12
j150
Jeff
F-150 Lightning 2023 Lariat Extended Range.
Wife took it for a day trip after we the truck in the dealer as it was unable to go into gear.
This is a bit of duplication since we are dealing with multiple issues.
During her trip, she stopped to charge, like she has done many other times in the Yakima area.
  • Charging faults and error messages when she went to charge at EA.
  • Switched chargers a couple of times so she could get home.
Multiple charge faults at home the next day.
  • Getting the thing charged up enough to take to dealer if needed.
  • This is really feeling like the update last week has messed things up.
Home charger confirmed working fine, as we have a second EV charging just fine.
It has also just stopped charging at home. No fault, just stops.
Again, we have another EV and the charger works just fine.
Do you have time or SOC limitation rules on the trucks Sync system?
Delete and recreate them.
j150
Jeff
No time restrictions, but there is a limit. I will check that.
Thanx!
Knichs
Boston
2023 F-150 Lightning
I'm having the same issue with our home charger. Our 2nd EV will charge fine but the Lightning is giving me "Charge station fault now". Will try to delete the saved limit and see if that helps.
Henry Ford
Was there any normal charging between the update and the charging issues? Was your wife able to charge at an EA station? At the DC charger were the fault messages the same as you see at home? Do you have any way to look up DTCs?
j150
Jeff
There was some normal charging. The EA session she needed to move a couple of times.
Home charging we have seen faults as well as just stops charging.
Dropped the truck off at dealer yesterday. They looked at the error codes and said they were all the way up to Z.
I assume all the way up to Z means 26+ error codes.
Heliian
All of our trucks will store and send error codes in the background, interpreting which codes are valid concerns is the tricky part.
j150
Jeff
Dealership has contacted Ford.
Holding pattern.
j150
Jeff
Ford is having the tech pull the bed off and look for chafing in the harness.
This is not a good sign for longevity.
The truck has 71k miles on it.
j150
Jeff
Wiring harness issues on the rear motor. Will be under the electrical warranty, so not gonna be a problem, this time.
Hopefully they can provide some more detail and also hope there is some kind of correction to eliminate this kind of problem in the future.
I would hate to have to do this every 70k miles.
After the final fix is complete we can rename this thread to include actual issue(s)
j150
Jeff
So, here was the real problem.
  • Removed frunk to access BJB.
  • Found high resistance present in sbb08 between BJB c1035b and sobdmc c3471c.
  • Removed bed to access c407 to isolate 14405 harness. Found OK.
  • Found high resistance isolated to 14a411 harness.
  • Removed GFM2 to access harness. No evidence of chafing.
  • Harness is on back order. Began cutting sheathing to perform overlay.
  • Found a pin hole about 2 inches from c407 in circuit sbb05 that caused corrosion.
  • Cut out bad section of wiring and spliced in new wiring.
Covered under electrical warranty.
Jesse-Infotainment
Jesse
2024 F150 Lightning Flash
That is a good tech.
