Charging Faults since update in March 2025
j150
F-150 Lightning 2023 Lariat Extended Range.
Wife took it for a day trip after we the truck in the dealer as it was unable to go into gear.
This is a bit of duplication since we are dealing with multiple issues.
During her trip, she stopped to charge, like she has done many other times in the Yakima area.
  • Charging faults and error messages when she went to charge at EA.
  • Switched chargers a couple of times so she could get home.
Multiple charge faults at home the next day.
  • Getting the thing charged up enough to take to dealer if needed.
  • This is really feeling like the update last week has messed things up.
Home charger confirmed working fine, as we have a second EV charging just fine.
j150
It has also just stopped charging at home. No fault, just stops.
Again, we have another EV and the charger works just fine.
Do you have time or SOC limitation rules on the trucks Sync system?
Delete and recreate them.
j150
No time restrictions, but there is a limit. I will check that.
Thanx!
Knichs
Boston
2023 F-150 Lightning
I'm having the same issue with our home charger. Our 2nd EV will charge fine but the Lightning is giving me "Charge station fault now". Will try to delete the saved limit and see if that helps.
Was there any normal charging between the update and the charging issues? Was your wife able to charge at an EA station? At the DC charger were the fault messages the same as you see at home? Do you have any way to look up DTCs?
j150
There was some normal charging. The EA session she needed to move a couple of times.
Home charging we have seen faults as well as just stops charging.
Dropped the truck off at dealer yesterday. They looked at the error codes and said they were all the way up to Z.
I assume all the way up to Z means 26+ error codes.
