Charging with 14-50 outlet in California - Issues
5 years ago I was remodeling my current home. I'm a licensed General Contractor. When doing the electrical and installing required GFCI breakers per code at the time, Including to Refrigerator, washer/dryer circuit, disposal circuit, dishwasher circuit, etc... I questioned the motor loads on GFCI's because I heard they could be a pain. The inspector agreed that the motor loads can be a nuisance causing GFCI breakers to trip. My wash machine breaker has tripped probably 5 times in 5 years from a GFCI fault. The disposal did almost every time I turned it on.
I may have altered breakers after the inspector signed off on my job. He may or may not have told me that "what I do after he leaves is up to me".
All is well.
Do as you wish in your home. A tripped GFCI doesn't necessarily mean you have a bad charger.
Generally, a refrigerator, washing machine or disposal doesn’t require GFCI per-se. Depends on the details. Dishwasher, yes (Stupid decision by the code-making panel).
Generally, a simple motor isn’t an issue. Many modern appliances have inverter drives running the motor that cause issues.
jimfigler
Orchard park, NY
Just swap the breaker after the inspection. They might as well GFCI the main breaker as basically that is where code is heading.
