Ruination
Neither of us is a battery expert. I am basing my comments on two things, ownership of four Teslas, from an early 2012, through a current MX, and seeing the degradation (mostly lack thereof) in my cars vs others with more cavalier charging habits, and second, Elon Musk's statements about level 2 charging and speed, as well as recommended storage levels - he specifically said that charging slower is better due to lower heat, and maintaining at 60% (instead of the default 90%) increases battery life. Another data point is the most recent Apple charging algorithms for the latest Macbook Pros, which allow SOC to drop without recharging, based on its analysis of user habits, and then charges slowly, not using the full amps available from the newest big brick chargers that come with the computers, to a level below 100%. Their explanation for why they do this is that gentler charging, at lower amps and heat, with less use of lithium battery extremes (zero SOC or 100% SOC) has proven to increase battery life, so they've figured out how to maximize this in the latest algorithms. Now, if you want the latest Apple laptop to show 100% SOC or to charge at the max available rate, you need to over-ride the default battery settings. If that's true for small lithium ion batteries, there's no reason it isn't true for an EV. And Elon said it, so I beleive it anyway.![]()
So, what are you going to charge your lightning at?
