Class Action Lawsuit - Home Integration System
Runaway Tractor
Yes
Sorry but there is NOTHING in that thread or video that indicates or shows DC charging into the truck. In fact nothing shows any charging at all, whether it is or isn't. He's guessing and not actually saying anything factual. Furthermore, he claims his charge limit is set for 90%, discharged to 89%, and now magically at 92%. So just totally unregulated blindly dumping DC back into the truck? No. It's not. That's not happening. No system would ever be manufactured to do that. The flashing green light on the FCSP indicates quote " The station is powered by battery backup, plugged in and discharging "
Also, you're suggesting that Ford, Siemens, and Sunrun all just forgot to document this Level 3 charging function?
v2h8484
Tesla Model 3
I find this highly unlikely. There is NOTHING onboard any of the HIS components the regulate HVDC charging. There is no level 3 charging communication between the truck and FCSP. There is no way this is possible.
The truck most likely does not do anything to explicitly support or block DC charging in the setup. However, once the truck closes the HV battery contactor (for discharging) then no comms are required to charge the battery. The Delta inverter is bidirectional so it will simply push any excess solar power back through the closed HV battery contactor to the truck.
tearitupsports
Russell
Houston, TX
F-150 Lightning Lariat ER
Exactly this. The Delta inverter is a 400v system and has no issue sending energy back the the truck. The truck does not display what is going on properly but it is working. In the video he notes that it charged 4% while on the HIS off grid. It would be slower than the level 2 AC charging.
Runaway Tractor
Yes
I'm aware the inverter CAN work in both directions. Just like it would with a 400vdc power wall.
What I'm saying is that no engineer with a brain would set it up to allow that. Arbitrarily pushing random excess power into the truck battery is dangerous and unrealistic. And again, where is this "feature" documented?
Assuming what the guy says is true and actually happened, that sounds like a configuration problem on the inverter since I'm not aware of any documentation for this to be enabled.
All that said, if it was mine, I'd probably try to configure it to do that, but very very carefully with safety of the truck battery in mind.
v2h8484
Tesla Model 3
Lol ... the same engineer that decided to use Bluetooth for a critical control function?
Based on all the reports in this forum It should be clear that Ford has overlooked many things in this contraption. Having said that, I am pretty sure the truck battery BMS will still shutdown the battery if necessary to prevent overcharging related safety issues.
Runaway Tractor
Yes
LOL exactly. I would hope it has some safety that will open the HV relays when the battery is full. But who knows what those conditions are.
Jim Lewis
San Antonio, TX
a new FCSP with 2.112.91:2.149:1.32:1.53:0.62 software, and the newest inverter software (revision 1. if memory serves?
Here's a hint that progress is crawling along, perhaps in an effort by Ford to finally get the HIS unit out of class action territory. Prompted by @Aminorjourney's post, I took a look at my long-ignored inverter via the M Professional app and just found another inverter firmware update. I had been at 1.1.21 since October 2023 and was surprised tonight to find I'd been updated to 1.1.33 since August 2024, with 1.1.34 available when I just checked tonight:
Ford F-150 Lightning Class Action Lawsuit - Home Integration System IMG_1072
I checked to see if there was a Delta inverter system log. The best I could come up with is, when logged into my inverter via the M Professional app, go to Menu, Analysis, Log, EVSE Log, then hit the SCAN button (top right). Here's what I get:
Ford F-150 Lightning Class Action Lawsuit - Home Integration System IMG_1073
The first date, 6/12/2023, was the date the system was installed and rendered active by Sunrun. The 10/7/2023 date is the approximate date window that the 1.1.21 firmware self-installed based on my following post: https://www.f150lightningforum.com/...backup-power-without-sunrun.12564/post-342129. I bet 9/1/2024 was the date the inverter updated itself to firmware 1.1.33. And the date and time on 10/7/2024 is when I manually updated to 1.1.34. Would be nice to have info from Ford on what each update was supposed to do for the system...
Aminorjourney
Internet
vehicles that go
Yesterday, I did ANOTHER test of our HIS. Prior to this most recent round of updates, I had to park my Truck off to one side on some gravel next to our driveway, skewed at 45 degrees to our Chicken coop so that the HIS would actually talk to the truck.
Ford F-150 Lightning Class Action Lawsuit - Home Integration System IMG_5689
However, yesterday, I was able to plug the truck in while it was parked ON our driveway, and it worked 100%! This hopefully means the communications have been fixed betwixt charge station pro and truck.
(My wife fixing the chicken coop has nothing to do with this lol)
Ford F-150 Lightning Class Action Lawsuit - Home Integration System IMG_6768
We ran it for about an hour with no problems.
As with the last test we did, we noticed no dramatic changes in voltage while the test was running, with draw as loss as 1.6 kW and as high as 8 kW. The Delta team seem to have tweaked the tolerances for power supply, which should mean no more flickering lights when the pump house turns on one of our well pumps.
I also turned on the truck while it was powering the home and checked that it could still provide pro power. It could on all sockets (although I didn't put a high load test on)
Wattsgas
MIke
Brinnon, WA
Thank you for all of your documentation and work on tracking and working toward solving the intermittent Ford sometimes Intelligent Power backup system.
Aminorjourney
Internet
vehicles that go
Glad to be of help!
Without divulging my actual address (because, hey, this is the internet and people aren't always that nice) - I'm in an area with absolutely abysmal cellphone reception (foothills of the Coast Range) so I usually manually check once or twice a month.
I would *love* to know if you suffered fluctuations in voltage before this update and, after applying it, if those fluctuations have gone away?
Jim Lewis
San Antonio, TX
You don't say how you observed those fluctuations - or I missed it. I have never observed voltage fluctuations large enough to cause lights to flicker or anything like that, but I've never tried to measure the line output directly during BPT (backup power transfer). I always test my system when the current draw is very low, < 0.5 kW, so that might be a factor. The only "power-hungry" device that is typically on during any BPT test is our refrigerator. The rating plate on it says it only draws 7.2A at 120V.
There might be a way to record line output via M Professional directly. If you go to Menu, Analysis, History, System History Charts, you'll find all sorts of data for the last 10 days of operation. Early this morning, when I was playing around with M Professional, there was a plethora of data, but only for 10/2/24, the day I did the backup power transfer tests I've reported. This evening, for some unknown reason, those charts are now blank. Here's an example of one set of many charts that was full of data earlier today (I don't know whether the inverter firmware update erased the history? - there's still some EVSE truck charging data left, though). There were real units on the Y-axis of the charts and real times from midnight to about 5 AM along the x-axis when I checked earlier today. Now all that's gone.
Ford F-150 Lightning Class Action Lawsuit - Home Integration System IMG_1076
One confusing, perhaps erroneous graphing of the data points previously displayed is that they were all connected by straight lines, point to point, giving very saw-toothed curves. My interpretation was that the only purpose of the lines was to connect the data points - that they revealed nothing about the state of the system between data points.
What I should do is perform another backup power transfer and immediately after I terminate it, return to these history charts and see if data populate them. IIRC, voltage, and kW power output were also one of the many available output/history charts.
A further comment relative to my previous post is that it is possible to trigger a manual inverter firmware update if you see a RED "Update Available" message on the main screen of M Professional. Otherwise, the firmware will eventually auto-update itself. I'll skip providing any manual update instructions.
I may also be on new FCSP firmware. Since at least 8/11/24, I've had an update pending notice in my FCSP settings as shown in FordPass: Ford Motor Company has the MOST sophisticated OTA update system...??? | Page 4 | Ford Lightning Forum For F-150 Lightning EV Pickup: News, Owners, Discussions, Community (f150lightningforum.com).
IIRC, sometimes such updates go through, and the notice just keeps hanging around.
