TomB985
Isanti, MN
2022 Lightning XLT ER
Based on how this appears to work, our problem of not having a "button" to pre-condition the battery (at least for hot weather) before DCFC on long trips without using the Ford nav system would be resolved... Love hacks like this 😀
I’ve spent lots of time towing with mine, and I’ve been really disappointed with the inability to precondition. The truck doesn’t seem to care if I navigate to a DCFC unless the battery is over 93º, at which point it’ll engage the A/C compressor to chill down to about 90º and stop. Charge starts to throttle down to 100 kW around 97º, which doesn’t take long when you’re starting that high.
Most of my trips have been in tow/haul mode because I’ve got my camper behind me, and I’ve never noticed a difference in battery cooling. I’ve given up using the truck’s navigation because it doesn’t make much difference. I’ve pulled to the west coast twice, San Antonio once, and am leaving for Texas and New England next week.
I’m obsessive about monitoring my temperatures, and I’ve concluded that none of it makes a bit of difference. The truck does what the truck does, which really sucks for fast charging on a trip.
Shawnson
Edmonton
Lightning Lartiat ER, Model 3 LR, Crosstrek… hehe
Developer
Only if you have selected a trailer profile in my testing, you can be in tow/haul w/o a trailer, ie. hauling a heavy load in the bed of the truck.
Sounds like my transporting my 4 ratchet straps around! 😎
3rdgenfan
Geoff
Delaware
Checking in from Canada... Does it do the inverse for a cold battery, I wonder? 🤔
I'm assuming there is a temperature range the system calls for, as when I tested this a month ago it only seemed to bring the battery down to 95*F from the higher 120-130 after a DCFC session, but when I tried it when the battery was sitting at 72* to see if it would raise it to the 95* mark, it didn't make a difference and the gauge cluster showed it in the middle mark the entire time; but that might not have been low enough to trigger the system to heat the pack.
invertedspear
invertedspear
AZ, USA
lightningcalcs.pages.dev
Do you have Max trailer tow package?
I have it, but was wondering if it would work for all vehicles?
Yes, this is with the max tow, Hopefully someone without the extra cooling can weigh in. I bet it would cool the battery but would also steal the "chill" from the cabin AC somewhat.
Wonder why Ford wouldn't just have the truck engage the additional cooling automatically.
Balancing range for the EPA would be my guess. It does take a noticeable hit to my efficiency, maybe about 0.2 m/kWh less when in tow/haul and it's hot as hell out.
So then it must be ok to run above the mid temp, but a hot battery is less range also right?
Yes a hotter battery over the top of ideal temp (about 75F) starts to hold less potential energy, but the effect isn't as great as a cold battery. The bigger problem with heat is that it accelerates the battery degradation. Living in Phoenix, and intending to own this truck for a long time, I am trying to figure out all the tricks to help the battery live as long as possible.
The question is - will the vehicle automatically kick in this extra cooling capacity on its own when I am not towing, or do I have to do it by pushing Tow/Haul?
It will, but it seems like in the other modes it's more OK with letting the temp go well above the midline, but in tow/haul it's far more aggressive on keeping it cool. Probably designed for better climate than what I live in where it thinks it will eventually be able to cool it down with less aggressive cooling. But even running around at night in normal mode, when the temp if still 95f+ the temp will raise above midline a bit.
I've noticed lately, with my PRO, that when I attach my camper, it no longer asks me to 'choose' anything: it just defaults to TOW/HAUL mode, automatically and the GOM adjusts, but that's it.
Iroc34a
Roc
23 Lightning Platinum
Mechanic for American Airlines. GSE (ground equipment) 37 years. Worked on everything from Lawn mowers to Boeing 747's.
Strange, been hotter than the hubs of hell this summer in STL. My gauge never went above middle temps? Ideas? ER Platinum.
Maxx
Same here in MD (Not like AZ). We have had a bunch of upper 90 days and a few over 100 and I have never seen the battery temp gauge go above middle line even when car scanner was saying battery temp is high. I was worried if the gauge is using a different sensor that may be off or dysfunctional. It seemed like cooling system never came on. I am glad I saw this thread. Next summer I have some testing to do.
Iroc34a
Roc
No kidding? Huh, guess I'll keep an eye on that too. Waiting on a laptop to run Forscan!
