Cruise Control Cancel's in the Same Spot
AmandaB
US
2022 Ford Lightning Lariat ER - Red
I have a 2022 Lightning Lariat ER and typically drive with adaptive cruise control on. I've noticed in the same location on a 4 lane road it will almost always beep and disable cruise control, and then say Cancel on the dash. I say almost always because I know at least once I was testing it and had no issue. Anyone had this issue reoccur in the same place over and over?
Edit: I'm not using Blue Cruise or Lane Assist during that time.
Do you mean that handsfree stops and requires you to put hands on?
The Weatherman
Dean
South Central KY
I use the Blue Cruise feature every time I travel to the nearest small town. The Parkway is mapped and it works great. There is one section where the system shuts down for about 200 yards and then comes back. It consistent and I have yet to figure out what there is about that section that shuts it down.
CdnCGM23
Jeff
Barrie, ON Canada
Military
I haven't with my Lightning, but with my Tesla yes. PIA and freaks my wife out all the time. She yells at me to just forget about the cruise control. I love Blue Cruise! So far, LOL.
I would think the issue has something to do with GPS mapping. 6 lane highway, happens in either direction. There doesn't seem to be anything about the paving or lane markers to warrant the sudden release in my situation.
AmandaB
AmandaB
US
No this is just regular cruise control without lane assist. Blue Cruise doesn't work hands free in my area.
AmandaB
AmandaB
US
It freaked me out the first couple times.
See if the area loses the lines, i.e. they are painted over, or faded and invisible to the camera.
greenne
Nathan
Niskayuna, NY
Yes.
On a two lane road I use for my daily commute the "lane centering" (non hand free Blue cruise) will disengage at the same spot. The speed function still works, but the lane centering function shuts down with a beep and "cancel" on the dash. Same spot everyday. I figured it was because there was something there causing the yellow center or white side line to be obscured and the system can't determine the lane.
On the freeway, it is well documented that the bluecruise "hand free" shuts off under the toll reader gantry on the New York Thruway
AmandaB
AmandaB
US
That sounds similar to what I'm seeing, but I'm not using Blue Cruise during that time.
AmandaB
AmandaB
US
That very well may be it. I will pay closer attention next time.
greenne
Nathan
Niskayuna, NY
On long drives on mapped interstate there are little sections here and there where Blue Cruise hands free will disengage and the engage again a short while later. These are gaps in the BC map..you can see some online
Heliian
The camera can't interpret the lines on the road. Could be faded markings or sun/shade.
If you find bluecruise is kicking off at the same spot, it's most likely a corner that is too tight for BC.
AmandaB
AmandaB
US
Yes.
I'm not using the lane centering during that time, but it does sound similar to what I'm seeing. It may be something with the lines it doesn't like.
The Weatherman
Dean
South Central KY
It’s not a curved section. It is straight as an arrow.
I’ve driven this section for nearly two years in a Maverick with lane centering without the same loss.
I’ve studied the lane marks pretty closely and don’t see any difference in them compared to the before and after.
My feeling is it something to do with Mapping Data.
Sounds like everyone here is focused on lane centering (e.g., LKA, Blue Cruise). But you’re referring to speed control, right? In other words your truck will begin to slow down and not maintain speed?
If so, my only thought is that you have speed sign recognition on and it sees what it thinks is a 5 or 10 mph sign and disengages.
