DC Charging Fault 151 miles away from home
GoodSam
Good
occupying space
If the broken charging actuator pin:
https://www.macheforum.com/site/attachments/tsb-22-2355-pdf.80021/
TECHNICAL SERVICE BULLETIN
Level 3 Charging - Illuminated Charger Service Required Indicator In The IPC And/Or Multiple DTCs
TSB 22-2355, 19 September 2022
Also via NHTSA:
https://static.nhtsa.gov/odi/tsbs/2023/MC-10233580-0001.pdf
Level 3 Charging, Illuminated Charger Service Required Indicator In The IPC And/Or Multiple DTCs
TSB 23-2014, 01 March 2023
If the charging cord is removed from the charge port without the lock/release button fully pressed, this can damage the charge port locking pin actuator and disable level 3 charging for the next charging session. To correct the condition, follow the Service Procedure to replace only the charge port lock actuator.
