Departure Times Just Will Not Work-Solved
Dfair
2024 Ford Lightning Flash
Damn, I am using that charger. I bought it back in December. Do you remember the version or what you had to do to get them to update?
My firmware version is 50.0.9. I haven't tried the departure settings in a few weeks, but will try it tonight
EVIQO's support team was aware of the issue, so should be able to help.
mxracer
2024 F-150 Lightning Flash
Wow that is quite a difference assuming thet follow normal version numbering. Mine is at 10.0.14...or we have different hardware. I have the plug in version Evpower J81Y
Dfair
Interesting. I too have the plug in version.
I'm leaving on a trip tomorrow, so will see if it works
mxracer
Well there was a big difference. They updated my firmware to 50.0.9 just now. Hopefully that helps. Thanks for the tip cause the app said I was on the latest firmware.
mxracer
Finally working... thanks for all for the suggestions.
I broke testing protocol and changed 2 things at once so I'm not sure which fixed it :)
I did the Sync reset yesterday and EVIQO support was on the ball and updated my firmware super quick.
I then setup all my departure times and set and extra one for 10AM this morning and it's working now.
I lean more towards doing a factory reset of Sync vs the EVSE firmware update but as they were both mentioned in the thread so I can't say 100% for sure which one or if both were the issue.
Ford F-150 Lightning Departure Times Just Will Not Work-Solved Screenshot_20250125_092018_FordPass
