Drive in 16 inches of water?
davidf01
CT
F-150 lightning
Anyone know what would happen to the motors if you drove in deep water? 16 to 24 inches deep?
Firestop
Firestop
Ford F-150 Lightning Drive in 16 inches of water? 1662583517762
FlasherZ
St. Louis Metro
I presume that Ford has taken some steps to seal what needs to be sealed for minor road water, but not 16-24 inches.
(Note - it's just a bad idea all-around. I've seen all sorts of corroded connectors from water infiltration, and while the motor and battery pack may be reasonably sealed, you're likely to end up with problems later.)
Yellow Buddy
Mid-Atlantic
Smart Ass
Know? No. Guess? Yes.
If you did that, nothing would happen to the motors, they're environmentally sealed. I'd be more concerned about the axles, shafts, rubber boots, etc. Especially since those shafts seem to show corrosion pretty quickly, dunking them in water probably doesn't help.
From the owner's manual:
Never drive through water that is higher than the bottom of the wheel hubs.
16 to 24 inches deep is way deeper. Don't do it.
F150KR
Raymond
NY
F-150 2019 Platinum, F-150 2022 Lariat
Lightning cannot do this?
Theo1000
Theo
Shawnee, KS
Audi Etron,Chevy Volt,BMW I3,Mach-E,F150 Lightning
Have a feeling Rivian will discover this was not a good idea or claim. Esp. in moving water or rough waters as folks will try. Some fool is going to get killed trying this in a bad circumstance...
davidf01
CT
F-150 lightning
Well sometimes you don't have a choice but to drive through deeper water. I was wondering if the truck would die or can it do it.
Sure you do. Unless it's life or death.
rdr854
Northern Virginia
18 Volvo V90, 22 Ford F150 Lightning, 23 Outback
Of course you have a choice. Turn around. It’s not worth the risk to you or first responders - even though they may be trained in swift water rescue.
BennyTheBeaver
2023 Lightning XLT ER
Test it out for us and report back!
Ken
Ken
Monterey
Lightning Lariat ER
there's a great video somewhere of a driver taking a tesla through a lake, they put a ton of weights in it so it would not float, and they basically drove it submerged through the lake multiple times.
edit- found it.
Lightning Rod
North Coast
2023 Ford Lightning Lariat ER
CNC PROGRAMMER/MACHINIST
edit- found it.
He's an idiot.
