Driver window misbehaving
KennyB123
Ken
Detroit, MI
Very strange behavior yesterday that continued today. I rolled the window down to order fast food. When I used the auto up feature, it went to the top and then auto lowered 2/3rds of the way down.
I can only manage to get it to stay at the top if I feather it with the half press to the near top. If I half press to the top, it will go down 2/3rds again.
I'm guessing this is a service call?
Ford F-150 Lightning Driver window misbehaving 1739406118106-yw
Ford F-150 Lightning Driver window misbehaving 1739406149659-xh
Zed
Chuck
2022 Lightning Platinum Rapid Red
I had this behavior last summer. I had to reset the one-touch close for both windows (both fronts, but not acting up at the same time) but the issue returned. I sprayed some silicone lube into the window channels at the front and rear of the windows and haven't had the problem since. 🤞🤞
I probably just jinxed myself...
jetfixr1
Manny
Atlanta
This isnt unique to the Lightning. At one point my last two ICE F-150s did the same.
jetfixr1
Manny
Atlanta
This is my first Ford. Glad it's so easy!
I can tell you now the turn signal stalk will also go at one point, my last 2 gave in within 3 years 😂😂 But thats probably more so from water intrusion when the rain comes in. Must be a Florida problem.
mattskr
Matt
Austin, Texas
23 Platinum Iconic Silver
I just recently had the same issue and I guess I disabled it in frustration by messing with the buttons.
Never had an issue with turn signals but on both of my last 2 F-150s the sunroof got stuck in the half open position upon opening it. I've now learned to no longer use the sunroof once the warranty expires.
MaintGrl
Marsha
El Sobrante, Ca
Ya, I found this out when I Installed my Weathertech Wind deflectors. It would go up, then immediately reverse. Quick fix for that
