iceman77
I did not have any installation issues with VX manager. It is possible their driver relies on various "redistributables" C/C++ libraries, which I have had already installed, hence I experienced no issues. The interface is set up to work with SAE J2534 (also known as Pass-Thru) protocol which itself is very fast. I used it with ForScan and it was much faster that their ELM327 interface. While the FDRS software itself is sometimes finicky (had the software freeze couple of times after network re-scan) I had never had issues with ForScanExcellent write-up. How large a flash drive did you use? You might want to add flash drive to your list of equipment.
Did you have any issues installing VX Manager? My installation was less than smooth. When I downloaded the latest Christmas Eve version, I couldn’t get it to install cleanly. My OS kept reporting missing installation modules. I could only install the earlier March version completely. Once I got that up and running, I was able to use the update button within the app to update to the latest version. I got to the same place, but it was clunky.
I haven’t had an opportunity to actually dig into FDRS yet. But did you have any installation failures using USB which you were able to get around by using the CAN bus pathway? Was it a lot slower?
Thanks for all the work you put into this write up.
