Yes, visit civilization once and a while and you'll get the downloadsWait, what?!
Do we need cell signal to get updates?
[sigh] I'm screwed...Yes, visit civilization once and a while and you'll get the downloads
If you have decent home internet, consider contacting your cell provider and asking for a cell booster. They hook into your home Internet and create a mini cell tower that will allow you to make phone calls, have 4gLTE data, etc.Wait, what?!
Do we need cell signal to get updates? Cell coverage at my home is MISERABLE with maybe one spot under the tree in the front yard being good enough to hold a phone call. This is obviously much much worse in my garage, which also happens to be 10' lower and surrounded by trees in the back yard.
That and you should consider taking the significant other to a nice Italian dinner in the big city one a month.Does the frigging thing need to be charging, lvb over 90%, battery tender running, hvb over 90%, and your first born in the backseat to download updates too?
Unfortunately I have one and it almost made the issues worse. With wifi I can do wifi calling and it works anywhere in my mesh network, when the booster is in place it defaults to cell and if you move anywhere the signal gets weak and drops calls all the time.If you have decent home internet, consider contacting your cell provider and asking for a cell booster. They hook into your home Internet and create a mini cell tower that will allow you to make phone calls, have 4gLTE data, etc.
Might help with your truck updates too, just know that the truck uses at&t towers to communicate.
Having the truck connected to wifi or having good/bad cellular reception will not determine when an OTA will queue up for you on the server. When an OTA trigger is created for your truck, then and only then does it matter if you have a good connection. First, you vehicle must ping the server back to let it know it received the OTA trigger. This only happens when the truck is turned on; whether you drive it or not. Once that handshake happens, the OTA will go through it's motions to verify the files and manifest. If this part checks out, then and only then will your truck try and download the files from the mothership. This is the time where it is important to have good cellular data.Unfortunately I have one and it almost made the issues worse. With wifi I can do wifi calling and it works anywhere in my mesh network, when the booster is in place it defaults to cell and if you move anywhere the signal gets weak and drops calls all the time.
On top of the poor cell reception they built my house with concrete board so I had to install an elaborate wifi mesh system just to work. Which obviously is part of the problem with the booster.
Personally, I also think the local transformer is going bad and flooding the whole area with rf. Half a mile up the road and half a mile down everything works. My house? Compete deadzone
The booster is a good idea though, I can throw that in the far reaches of the garage and not mess with the rest of the house
But having bad/no wifi and or bad cellular can cause it to NOT take place, right?Having the truck connected to wifi or having good/bad cellular reception will not determine when an OTA will queue up for you on the server. When an OTA trigger is created for your truck, then and only then does it matter if you have a good connection. First, you vehicle must ping the server back to let it know it received the OTA trigger. This only happens when the truck is turned on; whether you drive it or not. Once that handshake happens, the OTA will go through it's motions to verify the files and manifest. If this part checks out, then and only then will your truck try and download the files from the mothership. This is the time where it is important to have good cellular data.
So, you can have your truck parked under a cell phone tower with the LVB charged to 100% and it will make zero difference in terms of when an update will be sent to you.
I get I can't MAKE it happen, but being my truck is on 4.2 and has never updated
Pro ER so could have been a fleet order. It only had 100 miles on it when I picked it up so I don't expect it was a demo.I'm wondering if your truck is blocked from updates, was your truck originally a fleet order or was it a demo model prior to you buying it?
You would know if that was the case because you would have a notification of a failed update.But having bad/no wifi and or bad cellular can cause it to NOT take place, right?
I get I can't MAKE it happen, but being my truck is on 4.2 and has never updated I want to make sure it will when it can, but if where it is parked prevents that then there is an issue I should address.
No?
PM me the VIN. I can check if it is in fleet mode or not and if you have any obvious connectivity issues.Pro ER so could have been a fleet order. It only had 100 miles on it when I picked it up so I don't expect it was a demo.
To be clear, I have only had it two months so it hasn't been a long time. I have not tried all the "tricks" either.
