K6CCC
- First Name
- Jim
- Sep 12, 2024
- Glendora, Calif.
- 2024 Lightning Flash in Antimatter Blue, 2017 Toyota Corolla
- Occupation
- Two Way radio systems
Made an interesting observation with my newly installed Ford Charge Station Pro. It is not following the networking rules for DHCP operation. Once I set it up to use one of my WiFi SSIDs, it connected and requested a DHCP IP address from my DHCP server - as expected. The FCSP was assigned 192.168.206.192 with a 3 hour lease time. What is supposed to happen with a Dynamic IP address is that when the address lease has reached 50% of the lease time, the client device (the FCSP in this case) should request that the lease be renewed from the DHCP server. That is not happening. The DHCP address was assigned is apparently being retained by the DCSP presumably until it is power cycled.
Does anyone have enough networking knowledge and the ability to see what your DHCP server is doing to confirm this?
The problem with this is that assuming the DHCP server (your router in most cases) assigns an address to the FCSP and then the FCSP never renews the DHCP lease, eventually the DHCP server will put that IP address back into it's available address pool and it couple be assigned to some other device. Having multiple devices on a LAN with the same IP address generally does not work well.
