K6CCC
- First Name
- Jim
- Sep 12, 2024
- Glendora, Calif.
- 2024 Lightning Flash in Antimatter Blue, 2017 Toyota Corolla
- Occupation
- Two Way radio systems
For the short answer, DHCP is short for Dynamic Host Configuration Protocol. It is the process that assigns IP addresses to devices on a network. In a typical home network, the DHCP function is handled by your router (functioning as the DHCP server) - but it can be other devices. Typically the DHCP server will have a pool of addresses that it will draw IP addresses from, and you can in most routers assign a specific device to always get the same IP address (generally called an IP address reservation). For devices that you will need to access, it is generally preferred to have that device always get the same address.. Depending on the router, a DHCP reservation may or may not be in the address range of the pool of available addresses - I normally use addresses outside of the pool of addresses.ok, could you please explain these terms because i was actually having issues last night when i got home after the Qmerit certified installers finally installed my FCSP.
For the longer answer, here is some reading. Warning, it gets into pretty serious details that are beyond what most of you will want to read.
https://en.wikipedia.org/wiki/Dynamic_Host_Configuration_Protocol
