Labs4Lightning
before I added the extender I took a long cable and moved an access point outside, couldnāt get it to connect.I have not done anything yet, the Xfi-pod is still in order processing with Xfinity.
But the signal strength between the garage and house appears to get better in the evening, it connects to the router and got the update.
with my current setup, I can access the charge station settings with the CSP app.
still donāt understand why CSP shows different software version than ford pass app.
also seems that since the .70 update my charge rate is down.
next time you charge, if itās not middle of night, can you check your ford pass app after 1 hour and see how many kWh the ford pass app reports?
I charged yesterday and again no charger insights - seems since .70 update it stopped reporting.
thatās September in pic.
