UGADawg96
So finally had the opportunity to hitch up and run across the CAT scales.
Truck specs:
'21 Oxford White, 302a XLT PB 7.2kw 157, 4x4, Max Tow, Tow mirrors, 360* camera, Sport package, 20" Sport wheels, Co-Pilot360 assist 2.0, Interior work surface, Power adjustable pedals, 8 Sp B&O, Onboard scales, Tailgate step/work surface, Box link, Wheel well liners. Factory Payload 1523 lbs.
Added: LINE-X Premium. XPEL PRIME XR tint. WeatherTech HP mats. Rugged Ridge shackle isolators. Sporthfish rear seat release. Geolandar G015 LT285/60r20.
TT factory specs:
Grand Design Imagine 2250rk, UVW 5546 lbs, Hitch Weight 515 lbs, GVWR 7495 lbs, Length 27' 11", Height 11' 0", Axle Rating 3500
The chains were able to reach and connect to the hitch when straight, but they were too tight for my comfort for turns. So I used some shackles to provide a little more reach. Plus, a little more red on this truck never hurts
Before hitching, the front fender was 38 1/4 and the rear was 41 1/8
After WD hitching, the front fender was 38 1/2 and the rear was 39 1/2
Using a 4' level on the bed rail, the truck was dead level. Using the level on the TT above the axles on the horizontal seam, the bubble was between the lines, but rear shifted slightly, which meant a very, very slight tongue lean.
The truck's Geolandar LT tires were only inflated to 50lbs and the TT tires (Goodyear Endurance Load D Max 65 lb) were between 60-65 lb.
I used the sway control on the Recurve R6 hitch and disabled the F150's electronic sway control.
It was pretty windy today and going about 60-65 mph, I felt some sway with truck passes or occasional large gusts. It felt more than when I've towed with an HD, but it wasn't that bad really. I'm thinking next time, air the truck up to 65 lbs.
According to the trip computer, the MPGs were 8.5 over the 30 or so miles from the storage unit to the scales and back. We used tow/haul mode.
The TT had almost all our gear in it. We gassed the truck to full. The only thing in the truck with us was a pancake air compressor. We normally also bring our clothes, cooler, and camping chairs, but didn't for this first measurement.
The scales measured 3500 on the steer, 3900 on the drive, and 5660 on the trailer axles.
I think since the powerboost has a 4150 rear GAWR, it means we can load up to another 250 lbs on the rear axle.
Open to any and all feedback, support, or criticism. Thanks!
Pics below. Enjoy
Truck specs:
TT factory specs:
Pics below. Enjoy
