- First Name
- Brandon
- Jul 26, 2022
- Tucson, AZ
- 2022 Lightning ER, 2025 XC90 Recharge
Are your 2.4GHz and 5GHz named the same? I can't confirm it will work, but I was able to get it all set up with both active but different names (I added "-5G" to the name I used for the 2.4 so I'd know what I'm connecting to). There is a reset button inside the FCSP that will get it to broadcast its network again. The manual points it out I think (I seem to recall it was top left). I had 2 or 3 failed attempts before it finally finished the setup. I can't remember if I power cycled/let it update before I got it paired.Ok. I can't seem to get pass the "Please verify you are connected to wallbox network" message. I believe that I am connected because when I first tried to set this up a few days ago, the charger showed up in my available wifi networks and I entered the password and it seemed to have went through and it hasn't showed up in my available networks since. I have a strong wifi connection but it doesn't want me to get pass this message and cannot go any further in the setup. Before i tried setting it up today,I powered the charger down for a few minutes and powered it back on. Maybe i should wait to see if it updates tonight? Oh, and I also have the 2 wifi connections... regular and 5G.
