metroshot
- First Name
- Pat
- Aug 26, 2021
- Montclair, CA
- 2022 Lariat F150L + 2023 MME
- Occupation
- Networking Tech
Instead of forced to use SunRun & Ford's 80A FCPS EVSE, a company came out with an alternative bi-directional 48A L2 home charge & back up using the DC FC connector.
This option might be a hit for the SR battery Lightning owners...
https://www.emporiaenergy.com/how-the-emporia-v2x-charger-works
V2X Bi-Directional Charger Specs
Type
V2X (V2H/V2G) Bi-Directional / Level 2 / 48A
Inverter
Integrated silicon-carbide-based AC/DC inverter designed by BREK Electronics
Charging
Power: 11.52kW
Input: 240V/48A AC
Output: 0-450V/40A DC
Peak Efficiency: >98%
Discharging
Power: 11.52kW
Input: 0-450V/40A DC
Output: 240V/48A AC
Connector
25’ cable with CCS Type 1 connector
Interface
ISO 15118 V2G interface
Dimensions
Charging Station: 16" x 12" x 4" (406mm x 305mm x 102mm)
Charging Gun: 12" x 3" (305mm x 76mm)
Enclosure
IP66 waterproof indoor/outdoor
WiFi
2.4 GHz 802.11b/g/n
Temp Range
-40°F to 122°F (-40°C to +50°C)
Certifications
This product is in the design phase, with expected release in 2023. Like all Emporia products, the Emporia V2X Bi-Directional Charger is being designed with your safety in mind. It will be manufactured to meet the safety criteria defined by these international standards: UL1741SA (Inverter), UL 2231, UL 1998, UL 9741, UL 2202.
Type
Inverter
Charging
Power: 11.52kW
Input: 240V/48A AC
Discharging
Power: 11.52kW
Output: 240V/48A AC
Connector
Interface
Dimensions
Enclosure
WiFi
2.4 GHz 802.11b/g/n
Temp Range
Certifications
