Installing Pro Charger without WIFI
Hopeful
2011 F350 diesel dually, 2020 Platinum Escape Hybr
We’ve had the Pro Charger installed in our shop and found our wifi with extender reaches to the shop but not through the steel siding. We tried setting it up with me standing in the open doorway with my phone but our dsl connection is too slow and wasn’t recognized. So the electrician set it up manually and it charged ok but I’m wondering what the WIFI connection is required for and if we’re missing out on important features.
Reactions: GDN
Can you clarify which charger you speak of?
This is the Charge Station Pro, which has a CCS connector. You said "Pro Charger".
Ford F-150 Lightning Installing Pro Charger without WIFI {filename}
This is the Ford Connected Charge Station, which has a J1772 connector -
Hopeful
It’s the Charge Station Pro
In general, the WiFi connection provides the ability to get reporting, and to modify the behavior of the charger (change amperage, stop/start charging, etc.). Assuming you control charging from the truck, it may have no impact on you having no WiFi once it's setup.
jefro
F150, Corvette, Bolt EV,
There are plenty of EVSE's that have been produced that require wifi and a lot of the users have issues (like any modern wifi device I assume). I don't have a smart charger and have no need but you have to decide.
The solutions might be to use a powerline adapter to get wifi or ethernet near the charger or conventional commercial campus type device.
Ford claims it has a number of ways to connect. If you get lte then your cell phone might only charge $5 for IOT device access.
https://media.ford.com/content/ford.../ford-pro-adds-all-new-charging-hardware.html
VTbuckeye
Joseph
Vermont
This does not apply to the fcsp, but the EVSEs that we are using now, Flo home x5, (provided by our electric company) communicates with a PLC. The PLC then plugs into our internet router, so the EVSEs use the electric wiring of the house to communicate. I was concerned about the wifi signal in our garage with the charge point home flex (though the charge point evse would have been able to deliver more amps).
