Is there a winch solution for these trucks yet?
Zaptor
Zaptor
.......... Trophy husband
I ran across this the other day while looking for a front receiver hitch: https://www.ironbullbumpers.com/products/2022-2025-ford-f150-lightning-front-bumper
Not sure what I think about it and will probably keep looking. I prefer using a receiver mount so you can winch from either end and I don't need to carry the weight all the time.
Yeah, that's pretty fugly... Would be nice if it had contours more similar to the vehicle, not all angular and harsh.
GarageMahal
JT
2023 Lightning XLT SR - Iconic Silver
Data Wrangler
some guy
canada
2023 xlt er
powerline
Just got my lightning recently, so I haven't made any decisions yet, but I think I'm just going to use a recovery rope y bridle for the front, with a hitch mount for the rear. Run it off of my booster pack, which could be plugged in while running.
GarageMahal
JT
Data Wrangler
Made this setup for a front receiver. The winch is mounted on a receiver so can be used front or back. The receiver mounts to an alloy steel flange bolted through the front tow rings.
Very interesting approach. I have been pondering a similar approach that replaced the tow rings but never thought of connecting directly to them.
Any concerns about the mounts twisting or rotating where it connects to the tow rings?
GarrettBlake
Garrett
Santa Rosa
2023 Lightning
The clamp to the tow ring is a flange on the top which is approximately the same shape as the outside of the ring itself, a flange on the bottom which protrudes forward several inches and has two holes in it. There is also a spacer in the middle that fits snugly inside the ring. There is a grade 8 bolt and nylock clamping it on to the ring through the middle of the ring. The material for the top and bottom are AR500 steel. The spacer in the middle is common mild steel. The smaller of the two holes is for attaching the receiver crossbar and the larger hole acts as a tow point since the normal tow ring is being used by the clamp itself. In order to attach the clamp, a bit of the rubber boot around the tow ring had to be removed.
The anticipated loads on the clamp are from either the receiver mounted winch (or some other receiver mounted device) or from using it to tow/move the vehicle. In the winch loading case, there is a bar connecting the two clamps together which the receiver is mounted to. The load is largely longitudinal (tension along the long axis of the truck) and distributed between the two clamps. I would expect very little torsional load on the clamps in this scenario. The spacer in the middle of the ring should provide good physical contact with the ring in that direction and the bolt provides some sheer strength. The winch is rated at 1500 lbs, and it is probably low compared to the load to tow the vehicle. In order to allow towing the vehicle, the large hole was created. This should allow the vehicle to get hitched without having to remove the clamp on the ring. In this scenario, there should be little torsion on the clamp since a tow hook is being used. The forces on the flange follow the direction of the tow cable being used. If there were upward forces on that tow point on the lower flange, then the bolt on the clamp becomes under a much greater tension load. Assuming the bolt does its job, since the top flange extends to the edge of the ring, it would get the load transferred to the ring.
I have not actually tested any of it for strength, but some initial calculations showed that in the winch case it would perform quite well. In the towing case I simply don't know. The AR500 steel and grade 8 bolt are pretty tough relative to mild steel, it was just a solution to the problem that seemed appropriate.
dsyruptor
Greenville, SC
2021 XLT Powerboost
CPA
Any chance you'd consider fabricating/selling a couple of these adapters? I'd love to have the option to attach a front winch in a modular fashion that keeps the front end looking stock when not in use.
Yes! I ended up getting one of these, a 3-ton Power Puller, with synthetic rope, Made in USA by Wyeth. Have not had to use it yet…. But it avoids needs to modify or replace the bumper and air dam, mount a heavy winch, and having to run a high ampacity 12V connection. This, a tow strap, tree saver, and some snatch blocks are what I plan for my recovery kit stowed in my Frank when I hit the trails.
Where is your Frank?
  • Haha
Reactions: LOV
Ishkatan
Adam
Monrovia, Md
2023 F150 Lightning Lariat ER =RAe (Range Anxiety)
Old
I love the way you mounted the front bar to the tow ring extensions. You should patent that. Custom tow ring extension could be made for many brands of trucks.
Suggestions:
1) lateral pulls could cause the extensions to pivot. Add either a riser 3/4 the thickness of the tow rings and filling in most of the space in the rings so it presses against the rings in a lateral pull, or use 4 bolts right by the inside edges of the tow rings.
2) Consider heavy duty tractor hitch pins or wing nuts instead of regular bolts and nuts. The idea is to remove the steel extensions when driving on streets - reduce damage to pedestrians / things from frontal impact where the extension acts like a knife. I want to store the whole thing in the Frunk or under the rear seat.
When I get my Lightning, I plan on getting / making something like this and to use it with a 5000 lb winch I got on clearance from WalMart. A car/marine battery works fine for short pulling sessions and can be recharged by the truck with a regular charger (or some day, with a solar panel ?.)
GarrettBlake
Garrett
Santa Rosa
2023 Lightning
The extensions are welded to a piece of steel that fits snugly inside the D ring and there is another piece of steel on other side of the D ring itself, about as big as the D ring. The bolt really just keeps the whole assembly clamped together around the D ring in a sandwich. It cannot pivot because of the spacer in the middle. I believe this is what you are suggesting.
It only protrudes about 2.5 inches, so far it has not been a problem. I did not want to assemble a buch of parts in order to use it, so I bolted it up with some grade 5 bolts and nylocks. The only assembly required now is the cross piece and the receiver mounted 110v winch, everything held in place with 3 hitch pins.
Good luck with your setup when you get your truck.
Ishkatan
Adam
Monrovia, Md
Old
The extensions are welded to a piece of steel that fits snugly inside the D ring and there is another piece of steel on other side of the D ring itself, about as big as the D ring. ....I believe this is what you are suggesting.
Perfect. If you decide to make and sell these commercially please post here. If you make a Youtube video showing the construction also let us know the link. I think you would have a market for many different trucks that have front sensors.
Tom Jensen
Arlington, Virginia
F-150 Lightning 2023
Attorney
Mr. Blake - I will happily pay you for a front hitch exactly like the one you built. I move boat trailers in tight spaces. The front hitch is so helpful.
