Issue programming a new key
Kansan
Wayne
2024 Flash
Civil Engineer
That’s interesting. So this was purchased based off a link from another thread on how to 3d print a case to make a diy PaaK of sorts. I got the 315mhz and yeah it basically is a dud seems like, but this could explain it.
Pretty good reason to get a flipper zero as well tbh haha
The frequency of the key fob is printed on the circuit board inside the fob, under the battery. My 24 Flash shows 433 MHz and my 23 Lariat 5.0 shows 902 MHz.
EVpower
Northern California
2023 F-150 Lightning Lariat, Bronco II
Electrical Engineer
I was 0 for 20 tries programming a new key fob until I followed the instructions on fob placement in the back up slot.
CptnWookenstein
Western North Carolina
Lightning Flash 24 - #TeamAvalanche
Can you show exactly how you determine that?
So I have a 24' flash and I heard that same thing in another thread, recently I picked up a second backup fob in the 433mhz range and now this time I'm have zero success and getting the "failed programming" notification where the original 315 says successful but then doesn't do anything.
I feel like I'm missing something and or taking crazy pills
EVpower
Northern California
Electrical Engineer
The FCC ID numbers on the working fob and the fob to be programmed should be the same for the fobs to be on the same frequency band.
The ID is printed underneath the key.
Like @EVpower said, you need to check the FCC ID. See this post for a pic
https://www.f150lightningforum.com/forum/threads/issue-programming-a-new-key.18193/post-471106
CptnWookenstein
