Maxx
Could you imagine if they engineered a flip up seat for 2 in the bed that only unlocked when you attached a structural cap w/roll bar? That would be phenomenal
Any cool idea you can think of, GM has already done it.
GMC Envoy XUV
Ford F-150 Lightning PSA: Keep your Tesla NACS adapter cool 1720658057490-ou
Sneakypetie78
Pete
Marina del Rey, CA
2013 F150 limited
General Contractor
Oh I still have my Lightning, different tools for different things. Unfortunately my EV9 sucks at hauling mulch, and my Lightning sucks at seating 6.
Wait for the '26? T3...
PAndaemonium
Minnesota
MY23 Ford Lightning XLT ER
MyJoule
'22 F150 Lightning Platinum
We just completed a 1600 mile trip using the A2Z adapter with our '22 Lightning- The temperatures were quite hot the whole way- mid 110's across the desert from Phoenix to LA, and We saw 112 up the central valley of California - we stopped numerous times and had no issues with charge rate at any of the stops. Even the LA area was 105-109. The adapter did get quite warm to the touch, but that wasn't unexpected. Charge rates were good for the Lightning, Peaking at 170KW most times and tapering to the low 100's after about 10 min- We would charge until the rate dropped below 100 KW and proceed on our trip- The Tesla Superchargers all worked flawlessly. We didn't do anything special to condition the adapter or the charge cable/connector. I was aware that charging could slow if things got too hot, and we did see the Lightning's battery temperature move off the center after charging in the heat of the day- but never more than a little above center and it came back down overnight before departing the next morning on the trip.
Great to verify that the A2Z adapter doesn't cut out like the Lectron does.
Scott Libre
3rd Planet
Mach e
Space Lazer Repair Technician
I never understood why manufacturers of items that may be out in the direct sun to use black as a finishing material, for example, dashcams and outside security cameras. EA uses a white shell on the connector piece.
I installed six white security cameras 7 years ago, and have not had an issue with any of them in the hot blazing sun of Florida.
husky10101
E Wa
Glad I don't live where it gets 100 or above
Redwood
Craig
Portland, OR
2023 F-150 Lightning XLT ER
Just finished a 1500 mile trip with the A2Z adapter. Charged three times on the last day at superchargers with temps ranging from 90-104F. Kept the adapter inside the cab between stops.
The warmer the location, the slower the charging (as expected), but no failures of the adapter. Worked great!
