GarageMahal
JT
Minnesota
2023 Lightning XLT SR; 2003 Mercury Marauder (For Sale)
Data Wrangler
Texas Dan
Daniel
'04 Envoy XL 4WD, '15 Fusion Energi, '19 Niro EV
No Lightning's listed. Fusion PHEV & Mach-E, listed, but NO Lightnings
This was discussed extensively in the previous thread and on the website. The modern factory manuals are taylor made. You enter the VIN and you get a taylor made manual.
So YES the Lightning is available on the factory-manuals.com website, that’s where I bought mine.
RickKeen
Minnesota
F150L SR Pro
sw engineering manager,
The fluid in the differential/final drive is going to age less than the diff/axle in a conventional vehicle. With an active pump and filter, its going to stay clean for a long, long time. With clean fluid, the gears and bearings are going to last nearly forever as well.
My prediction is that the seals or the pump will generally be the first things to fail.
I agree with the poster who mentioned that if you ever do swap the oil, it will; be way less work to just suck it out with an extractor from the fill hole and the port where the filter connects.
Rlevans
Russ
Asotin WA
2023 Lariat F-150 Lightning
Well, just spoke with service advisor and its looking good.
He says they have been test driving it and 1 pedal works and codes are gone.
Cautiously optimistic for now.
I'll post the codes and info when I get it.
