- First Name
- CHRIS
- Dec 16, 2022
- alexandria virginia
- 2023 LIGHTNING PRO, 2012 Nissan Leaf, 2015 Toyota Prius, 2000 HD 883 Sportster
- Occupation
Yes, fast DC charging puts the most thermal stress on the battery.I personally wouldn't worry about charging at 80 amps vs 30 or less. The Lightning battery is so big that you are picking between slow and slower charging.
Consider most consumer lithium packs that are in cell phones, laptops, power tools etc. are designed to be charged 0-100% in about 1 hour. Despite having no thermal regulation, being charged to 100% regularly, and being designed for maximum energy density over longevity, you can still get around 1000 cycles out of these batteries before they are done.
Even at a full 80 amps it would take 8 hours to charge a Lightning, so you are essentially charging your lightning cells 8x slower than the scenario above, without all the aforementioned drawbacks that consumer lithium batteries encounter. You'd have to exclusively DC Fast Charge in hour long sessions to emulate the stress that is put on lithium batteries in other applications.
Tesla seems to predict that their batteries will last 500,000-600,000 miles, which would be about 1700-2000 cycles on a 300 mile battery. Seems achievable if the thermal and BMS systems do their job, charge to less than 100%, and excessive DCFC isn't used. I'd be pretty happy with a 500,000 mile battery cause it would probably last the life of the truck. So if I ever have an electrical panel with 100 amps of spare capacity, I'll happily install my Charge Station Pro and charge at 80 amps.
EV batteries have lasted longer than the predictions, and calendar degradation is not as bad as once thought.
Heat/temperature are the biggest issue so thermal management is critical.
The higher the current the higher the temperature no matter how big the battery is, which is why manufacturers always say to limit fast charging to prolong battery life - fast charging is higher current and higher temperatures in the battery will result.
So 30A will put less thermal stress on the battery than 80A just based on the physics.
Add to the charging induced thermal stress the ambient temperature if one lives in a hot climate.
How much that 80A vs 30A would affect the lifespan, I can't say for certain, maybe it would be negligible. But if you have the time, slow down the charging rate, especially if the ambient temperature is above 70 degrees. Also, let the battery cool down after use before recharging.
You get 8 years, 100,000 miles of battery warranty with the Lightning and pretty much all other EVS. That's a warranty that the battery won't completely fail or fall below 70% of capacity within the time and mileage limits.
But there is a gradual decrease in capacity over time even before you reach the limits, mostly dependent on the thermal stress from charging/discharging and the ambient conditions.
So one thing that might not have been considered the calculation is the gradual decrease of range over time to reach that 500,000 miles mentioned?
According to Car and Driver Tesla's Model S maintained 90% of their battery capacity, a 10% loss, after 150,000 miles in one crowd-sourced study. A model S lost 6% after the first 20k miles, but then didn't lose more until 40k miles 2 years later.
https://www.caranddriver.com/research/a31875141/electric-car-battery-life/
Another thing in the calculation is the "300 mile battery" assumption.
For longevity one wants to not go above 80% or below 20% capacity.
That extended range 320 mile battery in the Lightning is the EPA estimate based on a 100% charge multiplied by a .7 fudge factor so EV drivers don't over-estimate how far they can go on a road trip and run out of juice.
https://www.greencars.com/greencars-101/how-epa-estimated-range-is-calculated
If you only charge to 80% and discharge to 20% and you'll have to reduce the range accordingly, probably down to around 200 miles of range under ideal circumstances.
The real-world range is going to depend mostly on the load - pull a trailer on the highway will cut the range substantially, for example - but also the ambient temperature. Very cold or very warm will reduce the range in real life, optimum temperature is 70F, despite the on-board battery heaters and coolers.
Run the AC or heat - cut the range.
One poster here or on another forum travels from east-to-west coast pulling a trailer behind him and fast charges every 100 miles, except for when he stops overnight then he L2 charges.
So that 320 miles became 100 miles in real life very quickly.
And reaching 500,000k miles is 3 times more cycles.
Still, the Lightning should be adequate for average use and last the 8 years/100k miles (10years/150k mile in CA) even adjusting for those factors I'd bet.
Tesla is aiming to get a 1 million mile battery one day!
