Sport Mode
FrunkMonk-e
Utah
F-150 Lightning Lariat, Mach-e GT
Is there a way to keep the truck in Sport Mode 100% unless I turn it off? It's annoying to have to set in Sport mode every time I get in the truck.
Every now and then, send a request on the feedback widget.
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
Retired EE
How is it that my Mach-e can stay in unbridled (sport mode) but not my Lightning?
Because your Mach-E doesn’t have an Off-Road mode that turns off stability control. That was the problem on the Lightning. NHTSA rules require that stability control has to turn on with each key cycle so the truck can’t be left in Off-Road. Hopefully they will release a version that allows you to choose between Normal and Sport as the default and only have to confirm in Off-Road.
reffahcs
Tim
Tampa, FL
Ford F-150 Lightning
On my last road trip, I found Sport Mode gave me the best efficiency. Is that possible? SeeMs counterintuitive.
My guess is that it has more regen than normal mode. If you're in sport mode at highway speeds and take your foot off the gas, the truck slows down much more aggressively compared to normal mode.
Bhinde99
Maumee, Ohio
2023 f150 lighting
Construction
I'm finding the same thing.
FrunkMonk-e
Utah
Thanks for the explanation. It seems like a simple software solution.
soundpro
Langhorne pa
F150 lightining lariat
Business owner
Short mode has more aggressive brake re-gen, so it is possible
Nolander
Scott
2023 F-150 Lightning Lariat Extended
the regen is more aggressive so that may be a factor. I think all sport mode does is adjust throttle response so if you still drive conservatively, you certainly could achieve better efficiency.
ScubaSteve_TheReal
Steve
Midwest USA
Derivatives
I’m in sport mode all the time, but having to press ok on each start cycle is ridiculous in order to stay in the street driving mode of my personal choice. I can find no federal rule or regulation otherwise dictating this requirement to default back to normal mode…period on each ignition cycle btw.
carys98
Cary
Raleigh, NC
Retired EE
Here is the NHTSA report that led to the recall when Ford tried to implement the change. It would be fine to leave the truck in Sport but the way it was implemented it could also be left in Off-Road which affected the stability control settings. Hopefully they roll it out again in line with the regulations.
https://static.nhtsa.gov/odi/rcl/2023/RCAK-23V801-3529.pdf
mb0220
Matt
2022 Lariat ER
Sport mode changes throttle response and steering feedback.
You will find it can be as efficient as normal mode if you modulate the throttle properly.
Also has more aggressive regen-braking which can contribue to better efficiency.
ScubaSteve_TheReal
Steve
Midwest USA
Derivatives
Ok thanks for that, so it’s a fixable software item, Ford it seems just took the fast easiest blanket approach method. Driver profile setting method would be great idea. Definitely fixable ithen without breaking bad it appears then.
carys98
Cary
Raleigh, NC
Retired EE
The downside to agile software development. Move fast and break things is OK for social media, not so much for safety critical systems.
Randall Stephens
Seattle
2023 F150 Lightning Lariat ER
Jet Builder
Because it’s taking max regen from you before you have a chance to step on the brake. If you’re a late braker, you’ll see an improvement. If you are a slow coaster to stop lights, you’re already likely getting max regen.
Surfnturf
Hawaii
Lightning
It's still a problem because too many people blame users for being too lazy. I've complained and been met with responses like "what's 3-4 pecks on a screen every time you start your truck? I mean what's the big deal?" Or... "Why not just pay attention to your dash so you can press resume? How hard is it to press ONE button?"
I literally stopped using sport mode altogether because it really is a pain to go through that process every time I started the truck. It's absurd anyone thinks the drive mode resetting on every start up should be acceptable. Until people clamor enough Ford will do nothing to fix it.
