Tailgate struggling sounds ?
Iroc34a
Roc
23 Lightning Platinum
Mechanic for American Airlines. GSE (ground equipment) 38 years. Worked on everything from Lawn mowers to Boeing 747's.
Anyone else have a Tailgate that sounds like it's struggling to lift itself up? Works every time, but I still keep an eye on it!
FordBookends
West Coast
'23 Lightning Lariat, ‘68 Mustang Conv, 65 Mustang
Yup, same sound of the motor struggling. Occasionally it fails even though it makes it to the latch when the truck is pointing up hill. It always makes it on the second attempt.
Iroc34a
Iroc34a
Roc
Wonder if anyone has had to replace the lift motor yet?
Iroc34a
Iroc34a
Roc
EVmeritus
Griff
2020 Tesla 3, 2022 F150 Lightning
Electrification Activist
Had my tailgate fail about two weeks ago. It wouldn't open. Thought it might be a common problem and an easy fix. But it turn out it wasn't and took six days for my dealer to troubleshoot and fix the problem. They found that the top tailgate open / release actuators binding internally and ended up replacing both tailgate latch assemblies and the door lock striker.
Iroc34a
Iroc34a
Roc
Six days? Jeez. Didn't take that long to get to the moon! Lol. Well at least they figured it out. But lift motor still struggling ?
VAF84
Central Texas
2024 Sierra EV Denali
Consultant
Glad I'm not the only one. I had my bed sprayed right after purchase. For a while I was wondering if the spray added too much weight, but clearly the motor doesn't have any power to spare.
Henry Ford
Mine has always struggled. I thought maybe a counterbalance spring had failed but it's normal on F150s as far as I can tell. My buddy had a new Super Duty that has a tailgate that is light as a feather. Maybe it's an improvement for all F-Series?
Stalemate
Jeffrey
Seattle, WA
2004 Mustang v6, 2023 F-150 Lightning Lariat
Utility Electrician
Interesting, I wonder if this is similar to what's going on with my tailgate. Ever since I got the truck it takes at least 3 button presses to open. The first two presses result in a lot of clicking and beeping sounds. Kind of like the truck forgot what position the latches are in. After getting it open it behaves better for a little while. Had the dealer look at it the other day but all they did was adjust the tonneau cover and declare it fixed. It's not and it still behaves this way even with the tonneau folded back.
Firn
23 Pro ER
Can't you use one of those gas strut kits to give it a little more lift? Might have to change the strut itself out on one of those kits that prevents the tailgate from banging down, but that's pretty simple.
broncoaz
Cape Cod, MA
Mine new Flash tailgate is slow and sounds of struggling. I’m debating on shutting it off and seeing if I like it better.
Henry Ford
Nothing is broken. It was designed to act like an old man getting up from his favorite chair.
Henry Ford
This is not normal.
