AT193
- First Name
- Aaron
- Jul 1, 2022
- New Jersey
- 2022 F-150 Lightning - Lariat SR - Antimatter Blue
As my truck is currently sits waiting to be shipped, I'm getting my plan together for at home/at work charging.
My shop at work has three phase wye power, I can pull actual voltage readings on Monday when I am back in. I have scrubbed through some old posts but haven't found much detail about charging the F150L on three phase. Is there any advantage to having this third leg? Or would using it be way too much voltage for the onboard charger to handle? Current plan is for a wall charger at home, and at work I would use an outlet and a mobile charger.
Currently I do have a Nema 14-50 outlet, however it is hooked up as 3 Phase for a TIG welder. If that is a no-go and I have to wire in another one for the EV only, does it matter which 2/3 legs I use?
Thanks for any advice
