cowtown
- Mar 21, 2024
- Chula Vista, CA
- 2023 F150 Lightning XLT
If the efficiency hit is 10% of less, I'm thinking those will be my replacement. I dig it.
According to Toyo's testing it is approximately 5% for decrease in efficiency. Let us know if there is anything we can do to assist with your tire purchase journey.
They look to be comparable to the LT version.
It should 100% be less than 10%, if you put offset rims that stick out and ruin aero then you'll probably see 10%.
The range hit on my daily commute shows 1.9 miles per kWh still, so the range hit loss of 5% seems accurate as it hasn't changed over a couple hundred miles. Also, I've looked at them next to my buddy's brand new non-ev 35" ATIII's on his Tundra and they look pretty much exactly the same.Any early estimated efficiency numbers?
