So as we all freeze our tails off in our garage, here's a guy that modified a 7.5 kW garage heater to be powered from his EVSE / charger / "slightly smart charger cord" (his words). He tricks the charger into thinking it is plugged into a vehicle requesting power and it runs his garage heater.
He discusses 240V in the garage, garage heaters, hard-wire vs. plug/socket, charging technologies, etc. Then he briefly discusses the signaling pin and how it works. Later discusses charging losses and other topics that would be informative for newbies.
And finally why what he has done is a bad idea. He covers all the negatives and how things could go wrong in a hurry (amps mismatch, arcing, etc. So watch the video before you comment.
I like in the end where he discusses how we have a myriad of NEMA connectors that are all unique. But USB-C has figured that all out with Power Delivery. So why not smart plugs and sockets that negotiate the max volts and amps with a common connector. He even gives a shout-out to the Lightning at the end.
His charger is plugged into a wall receptacle. Wouldnt it be easier to plug the heater into the wall recptacle?
He covers that in the video. Bottom line, it isn't good practice to constantly plug and unplug these type of circuits.
GarageMahal
JT
Data Wrangler
Probably yes but I like this concept anyway as the outlets are not designed for repeated unplugging/plug events.
broncoaz
Cape Cod, MA
A proper Hubble or Bryant 14-50 outlet is $59. Proof of concept is interesting and all, but an insurance investigation wouldnโ€™t look kindly on it.
luebri
Neenah, WI
Danface
Dan
Central Mass
2023 Lightning XLT
Yup, spend the money on a high quality plug and swap the charger for the heater.
Ford F-150 Lightning Using your EVSE/charger to power a garage shop heater image000001
Cheaper in the long run and the insurance company won't have a reason to blame anything on you (they do that you know). Just because you CAN do it, it may not make sense TO do it.
RickKeen
Rick
F150L SR Pro
sw engineering manager,
Adding a 2nd outlet will need to be on its own circuit since the charger is considered a dedicated circuit even with the outlet connections.
Danface
Dan
Central Mass
2023 Lightning XLT
Have a plug on the charger and unplug it when you need to heat the garage.
CD4TNF
Technology Connections is an amazing YouTuber. His EV Beginners guide is hands down the best explanation of EVs. His few other EV videos are great as well. He mainly focused his YouTube channel on covering a technology in-depth on a relatable manner. He's talked about heat pumps, Christmas lightbulbs, refrigerator, EVs.
Yep, first I saw of him. The guy has over 2.5 million subscribers, more that 10 times that of Out of Spec/Kyle. He's not some stupid hack. It was a long video but worthwhile.
Folks that are replying to just plug it in to the same socket are missing the whole point and clearly didn't watch the entire video.
3rdgenfan
Geoff
Delaware
When we were watching his video on the christmas lights my fiance screamed from the couch "FINALLY SOMEONE UNDERSTANDS MY COMPLAINTS!" and bought like 4 boxes of them....which will be here in the summer some time.
I enjoy the in-depth explinations he puts out.
