carys98
- First Name
- Cary
- Jan 15, 2022
- Raleigh, NC
- 2023 Lightning Lariat SR
Ford specs the max for Lightning at 150 kW but they will actually peak at about 180 for ten minutes or so under ideal conditions. If you get lucky enough to find a perfectly working Electrify America site with your battery at a good temperature you’ll get into the 170s. It should also be possible on Superchargers but my experience so far is that the peak on a Supercharger is a little lower and it also settles into a lower rate. I’ve only used them on warm days so it may have been limited because my battery was a bit hot. The only vehicles that can do more than 200 kW are 800V architectures and the Lightning is 400V.I was under the impression that with V4, we would be able to achieve our top charging speeds (325 kWh?). Whereas with V3 most Of us are getting 150-220 kWh. But, I could be mistaken since I get most things piece meal through these forums. (Haven’t found a book on all this EV charging).
