You should post that with the caveat - the battery is very high voltage. Only qualified technicians should perform any maintenance on it.
Ford Senior Master
Pell City, Alabama
Service Manager
beatle
Springfield, VA
Nice to see Ford putting up instructions on repairing the truck.
Ford Senior Master
Pell City, Alabama
Service Manager
It's not rocket science, sure some will do what you said, but the vast majority wont. The better question is what the difference in size and shape between the SR and ER. Here in 6-8 years, even 10 years after the batteries are out of warranty, there will be plenty of people who do the swap themselves.
I wish them luck. I am sure some will be successful. Most will still end up at a shop for repairs.
right, no difference in the battery size/pack, although there may be other inverters/chargers for the larger battery...
Mike G
N. AL, USA
And at least one dealer has demonstrated how to not do it correctly on a Mach-E GT.
Link here.
Ford Senior Master
Pell City, Alabama
Service Manager
Exact same container. The standard range just has empty space in the battery hump.
Not really true. Both batteries have 9 modules taking up the space. It's that the cell modules are different. SR has 9 40 cell modules. ER has 8 56 cell modules and 1 40 cell module. This arrangement is different from the Mach E which as you noted was two modules less for the SR.
Ford F-150 Lightning BATTERY PACK REMOVAL GUIDE -- How-to remove your F-150 Lightning battery pack Screenshot_20220821-152915_Samsung Internet
Ford Senior Master
Pell City, Alabama
Service Manager
Link here.
Yes that happens with all vehicles not just EV's. Mach E may be more susceptible because of the way it is required to mount adaptors to the lifting points so that there is clearance to lower battery. Very poorly thought out battery mounting.
gorwell
Sacramento
Ioniq 5 / XLT Standard
Thanks for the update. And earlier video of a ford rep said that space was just empty for extended range.
