Viet658
Viet
Pomona, CA
2018 Tesla Model 3, 2022 Lightning Lariat ER
tommolog
New Jersey
www.youtube.com
2022 F-150 Lightning Lariat, 2023 Rivian R1S
Journalist
Hello everyone. I just posted my tire review video in which I compared the Lightning's stock General Grabber all-season tires to BFGoodrich K02 all-terrain tires to demonstrate the potential range loss when the tires have a more aggressive tread.
astricklin
99 Mercury mountaineer
I know the factory AT tire is a pretty mild tread but do you have a comparison against those as well?
skyak
F250, 911, Lightning
I image the 0.3 mile difference was probably due to slight difference in tire diameter?
Amps
Bolt
.0012%. — 1580 feet over 256 miles = mighty damn close, :) which could also be interpolated variance because the vehicle reports to only one decimal point
Bandit216
Alaska
Mach E GTPE, Lightning Lariat
For your range tests, have you considered using an ODB reader and the Car Scanner app to build a screen that displays the batteries actual kWh remaining? You can display it on the Lightning's center screen and it gives an exact battery capacity rather than the less accurate GOM and % remaining.
Ford F-150 Lightning All-Season tires vs All-Terrain tires comparison on F-150 Lightning Lightning Car Scanner A
I really need to get around to doing this.
mb0220
Matt
2022 Lariat ER
I replaced the stock tires with Mickey Thompson Baja Boss A/T size 285/60r20 mounted on 20x9 rims with +20 offset. (Stock wheel offset is +44.) I am noticing a fairly substantial efficiency reduction, like >10%.
astricklin
I'd guess that combination will take the same toll on an ice truck
mb0220
Matt
2022 Lariat ER
Agreed... It's the same as when folks talk about towing. The efficiency effects are basically the same between EV and ICE. Some may think I'm crazy to run these tires, but I rarely drive far enough to make range a question, and the additional cost per mile is small. I enjoy the aggressive look of the tires and I like the peace of mind of added capability in adverse conditions.
roddiaz1
Rod
Pittsburgh
Ford F-150 Lightning All-Season tires vs All-Terrain tires comparison on F-150 Lightning lightning-car-scanner-app-
WAIT!!! How is this done?
Curious minds want to know.
Seriously, where can I find how to do this?
Thanks
bigskylightning
Montana
2023 F150 Lightning Lariat (Extended Range)
Awesome - what app specifically are you using for this? It looks like, from the icon, that its this one.
Also, what scanner do you recommend? Would love to have this capability. Thanks.
-40 degrees? You live next to Santa Claus?
