Mike G
N. AL, USA
TSB 23-2169 was released yesterday (31 May 23) for '22/'23 MY Lightnings to address an issue where precondtioning of the cabin isn't working.
The fix is to update all of the powertrain related modules in the truck.
So that means the PCM, ABS, BECM, GFM2, SOBDM, SOBDMB, and SOBDMC would all get updated under warranty.
That's a nice chunk of update programming all done under warranty.
Attached are the details to reference when talking to your service advisor.
F150ROD
U.S. Navy Retired
Nice!!! Thank you for posting this! I am going in tomorrow for an unrelated issue so hopefully they will go ahead and update those…..
You’d think this would be pushed as a software update….
Mike G
Mike G
N. AL, USA
Ummm....Ahem...I suspect you're also having issues with preconditioning not working.....at least that's the assumption....
F150ROD
U.S. Navy Retired
Yup and most likely 100% of owners
jdmackes
2023 F-150 Lightning Pro
What issues are you having? My cabin preconditioning seems to work each time, even when not connected to my house (when I set it that way at least). Does it not work at all for you or just not very well?
shoopg
Garrison
Utah, United States
www.lightningretrofit.com
'22 F150 Lightning Pro | '21 Polestar 2 | '18 Charger Scat Pack | '98 Ford F250
Cloud Engineer
Excellent. I have never had cabin preconditioning work and it sucked in the winter. Hopefully this takes care of me. Battery was always warmed up though!
vacasity
Michael
Central Coast California
Ford F150 Lightning 2022 XLT
My truck will pre-condition one day out of the week. I thought i had my setting wrong.
I'm going in for a 20k mile service, so I guess i'm brining this up as well.
Some folks have intermittent functionality, while others have it working but outside the (past) the requested departure time, frequently happens on my truck.
I guess I truly have never used Preconditioning, but remote start has always worked for me. @Mike G - which, if any of those modules are not updatable by SW? Are there any? Just blows me away Ford would even mention doing this at the dealer. They should say that all trucks will have the updates within 30 days via SW push.
Damn - Ford needs more of Musk than just for NACS.
Mike G
Mike G
N. AL, USA
I'm pretty sure all of them can be updated OTA if that's your question. They have pushed out complete sets of powertrain updates for the Mach-E on a couple of previous occasions (once was actually a recall OTA) so it shouldn't be hard to do it for the trucks.
  • Love
greenne
Nathan
Niskayuna, NY
I was going to start a new thread..but....here we are...
Since I took delivery of the truck last November I've had intermittent but persistent issues with the Fordpass connectivity, pre condition functionality, and approach/unlock functions.
The truck would be fine and then go "dark" and not work--no pre conditioning, Fordpass not updating, etc. It started like maybe 25% of the time it would not work...now it works maybe 10% of the time(getting worse). I was thinking maybe a weak 12v battery is the culprit.
As if on cue, I just scheduled a service appt as my truck has not pre conditioned at the set time for 4 days straight(and not reachable on Fordpass app). Then miraculously it just came alive on Fordpass again.
I'm still taking it in to be checked out... but this is frustrating,,,
PS-- I am also having difficulty getting software updates. It usually takes several tries an OTA update will be sucessful..usually a dozen or more "failed" updates
