personalt
Did any of these contractors put an AMP meter on the panel and have you run 'all your stuff?' If not they are just guessing. (Unless they went around the whole house and wrote down the values from all the appliance plates and counted lights). You can get a really good idea of usage yourself with a clamp meter for $20 from home depot. Pull the cover, put the clamp meter on one side, turn on the max stuff you think you might run and see what the usage isi am op and have had two electrical contractor review my current set up . Using the nerc rules I don’t have the headroom in my current set up. I have 200 service to my house and my house mostly electric with two 5 ton ac units, electric stove, double oven , washer dryer and pool pump i have head room for 48 amp charger only . The only way I can get the 80 amp which needs headroom of 100 I would have to run a 400 run from the street. The cost been quote $15,000 to $18,000 and that not in the budget. I wanted the platinum ext battery is able to be charged with a 48 charger . I assume I would loose the automatic back up to the house. I just looking for directions.
