- First Name
- CHRIS
- Dec 16, 2022
- alexandria virginia
- 2023 F-150 LIGHTNING, 2012 Nissan Leaf, 2015 Toyota Prius, 2000 HD 883 Sportster
- Occupation
The actual specs from Ford say it will draw 32A continuous - so if anyone is thinking of using it with a 30A circuit, don't, 40A would be the minimum circuit needed (125% x 32A=40A per code).GFCI with 120v -- I don't know. The mobile unit has GFI in it, I think. So no need to worry about using a standard circuit. 120v charging a Lightning is horrid though.
Ford Mobile EVSE allows charging at 30A. Into a 40A or 50A 240v outlet there is no problem. 240v GFCI circuits are rare as heck. Only used with EVSE and perhaps the occasional pool or hot-tub. Ford "recommends" them, because NEC code now says the 240v plug used for EVSE needs to be GFCI. This NEC rule is NOT because the EVSE needs GFI. That is built it. Its because un-informed folks could pull out the 240V plug before disconnecting the J1772 plug. This will result in a nice little ball of electrical arc if the vehicle is actually charging. A lot more danger than just a 120v plug pulled while under load.
I didn't really answer either of your questions, but perhaps a bit helpful.
The Ford mobile unit really sucks by the way -- unable to derate to 24A, which would be so useful for folks that can find a 30A dryer circuit (need 80% derate for cont duty to 24A). But the Ford unit is $500 boat anchor. Sorry to be so negative. Portable units need to be programable -- whole purpose of portable is that you don't know what kind of power you are going to find......
My hot tub is hard-wired on a 60A 240V GFCI breaker in a sub-panel inside the house and a fused disconnect outside the house, per code, and inside the hot tube control box there is yet another fuse. Not sure how 'rare' hot tubs are, but 240V GFCI breakers are required by code. Code also requires a 120V GFCI circuit within a certain distance of the hot tub, maybe 50Ft?
Some hot tubs come with the GFCI built into a plug in set up.
You do not want two GFCI's on a given circuit if you don't want to have false tripping issues.
BTW, the power company installed a whole house surge protection with multiple ground rods after a few nearby storm-based lightning strikes hit nearby and fried some computer equipment in my house, also popped the disconnect box fuses on the hot tub and the HVAC - since then, no problems with surges.
There's always something...
