runawaytruck
Considering the F150 lightning for part time use with with a lightweight popup truck camper. Dry weight around 1200 lbs so fully loaded wet weight should be under 2000 lbs but not by much. Is anyone else considering something like this?
Any thoughts on how much the range would be reduced with this much load, and what suspension/tire/wheel upgrades to consider?
Any thoughts or inside info on when/if Ford will make the 6.5' bed an option?
Thanks!
Thanks!
