Wireless Phone Charging for Lariat and Below Models
mschiraldi
New Jersey
2021 F150 Lariat Sport 2.7 SCREW
Thank you again @Knickell for posting. Received my truck on Friday and just added this setup. Works perfect with wireless CarPlay and lets me close the lid to satisfy the OCD.
Ford F-150 Lightning Wireless Phone Charging for Lariat and Below Models F130DF0F-5653-43CF-A9B2-AB56469F89A8
Orlando150
Orlando, FL
Ford
Ok - issue with this.
I just got a new iPhone 13 Pro with an Apple leather case. The new case has a bigger lip around the camera. It lifts the phone just enough that it the rubber bits on this charger don't touch the case enough to hold it.
When I turn or accelerate my phone just slides off.
Update on the issue with the iPhone 13 Pro camera bump and Apple leather case. I tried out some different solutions and ended up with this which works pretty well:
I bought these Scotch Heavy Duty Gripping Pads for about $4 at Lowes.
Ford F-150 Lightning Wireless Phone Charging for Lariat and Below Models C1CBC2BC-3111-4DF3-B861-EBBEF6AF4B5B
I cut some small squares for each side of the charger which leave room for the camera bump to not be touching the pads. This allows the full surface of the pad to grip the phone instead of just edges if the camera raises the phone.
Ford F-150 Lightning Wireless Phone Charging for Lariat and Below Models 7ABEEACE-39F1-47CF-9DF5-ED45C0AE6352
The material is soft (no way it could scratch) but grips well. It's not glue or tape... it doesn't leave any residue on the phone. The back is a peel off sticker to hold the pads to the charger.
Ford F-150 Lightning Wireless Phone Charging for Lariat and Below Models FDCCA790-390F-4E53-8541-ED6BC914D89E
The charging area is raised but it is still close enough to charge. However I don't know if charge power is lower at that range. Update: I drove around for an hour streaming music and using Waze and the battery charge increased from 72% to 84% so no issues there.
Ford F-150 Lightning Wireless Phone Charging for Lariat and Below Models CD8CF1E9-A8E9-429B-B281-04A4A051D312
Just these little square pads are enough to hold the phone in place during normal driving conditions. Again this is with the Apple leather case but I think it would work with other cases too.
Ford F-150 Lightning Wireless Phone Charging for Lariat and Below Models D6A2F79E-CBBC-41AE-AA58-538E702FFD0D
Knickell
Knickell
Kyle
Mazda Protege, Ford F-150
Very nice! Looking good! ? ⚡
WillB17
Will
2021 F-150 Lariat Powerboost
Just so you guys are aware, anything that is not a Magsafe charger will only charge the iphones at 7.5W. If you need something faster (15W) you're stuck with magsafe. The only way to hit 15W with magsafe is most likely using the AC outlet since none of the USB ports have the juice to support 15W charging by the looks of this thread.
I think what I will do is install a 7.5W wireless charger for normal charging, and keep a 20W AC brick and lighting cable in one of the glove boxes when I need the fastest charging.
JediNut
Emmett
Rocklin, CA
'21 Ford F-150, '05 Harley Davidson Softail Deuce
I have to add my thanks to @Knickell for this setup as well. I originally went with the replacement center console tray on Amazon that had the built in charging spot. The charger in it was horrible. This setup works perfectly! Plus, I have the added advantage of an Anker charger, I have always liked Anker products!
kb2755
Ontario, Canada
'22 F-150 XLT 302A Sport
Just saw Anker release this new charger in their MagGo line-up.
https://us.anker.com/collections/chargers/products/b2930
Still waiting a while for my truck, but was hoping to get one of these and stick it in the same compartment as here:
Anyone with their trucks foresee any size/configuration issues? I'm getting an XLT so no top cover to worry about.
Di2
Thunder Bay, ON
2021 F150 Lariat, 2012 Challenger R/T Classic 5.7
You could just connect from the USB port in the truck, to the charging port on the phone. Less convenient, I realize, as you have to plug in and unplug the phone. Depends upon the level of inconvenience you're willing to put up with. I haven't decided yet what I will be doing.
kb2755
Ontario, Canada
This is what I currently do, but it's because my current car requires a plug-in connection for CarPlay. I hate having cables laying around in the car and having to plug it in all the time.
I want to take advantage of the MagSafe and just be able to throw it on when I feel like it. The Anker solution I quoted seems perfect, just want to make sure it'll fit in that cubby without issue.
Knickell
Knickell
Kyle
Glad it worked out for you @JediNut!
Knickell
Knickell
Kyle
Just “eyeing” it, it seems to be about the same size as the one I’m running, just a newer model. Looks good! May have to upgrade myself!!
kb2755
Ontario, Canada
Just for absolute, 100% clarity, the image below is what I'm looking to install in the cubby. I'm concerned with the height/length of the arm, want to make sure it'll fit in there:
Ford F-150 Lightning Wireless Phone Charging for Lariat and Below Models B2930011_TD_01_1200x
The image I used in my first post was stolen from a post above for reference to the location, not the charging pad solution :)
Knickell
Knickell
Kyle
Ahh, I will have to withdraw my statement then. Thought it was the flat Anker charging pad thing.
spizike9
Utah
2021 F-150, Lariat, Powerboost, FX4
Well I took it one step further and installed the MagSafe charger in the little cubby. Turned out good. Now I just throw my phone up there and it charges
Do you have links to the parts list? Where did you tap in for power as I see both USBs are still open. This looks very clean. Would love to do this to my truck.
ryan79260
Ryan
San Antonio
F150 Tremor (ordered)
Wait.... how did you run your power? This is exactly what I want to do.
Agreed!!! I attempted something similar, but always got an error when the MagSafe charger was plugged into the USB-C in that cubby. So, love the placement, but curious how the power is run as I don’t see any of the cords (which is a plus)!
Briansk12
Houston
2021 F-150 PowerBoost
I used a standard MagSafe charger. Ordered a 2.5inch flush mount from Etsy. Removed the cubby which is a pain because you have to first remove dash parts around the radio and the AC controls. I found a YouTube video on that. Removed the cubby. There are for screws holding it in 2 in front and 2 behind the sliding door. Those are hard to see. The sliding door comes out after those 4 screws are out then the cubby is held in by clips. Drilled a 2.5 inch hole in the cubby and installed the MagSafe and flush mount. For power I installed a usb socket in the back of the console. The one I got enabled quick charge.I debated wiring it to the back 12 volt outlet but ended up running power from the fuse box in the passenger kick panel. The magsafe wire is run through the console and plugged into the socket. Had to drill a small hole in the Console storage to get the MagSafe wire inside to plug it in. The attached picture shows where the socket is installed. You can see the MagSafe charger plugged into it. You could really put it anywhere, I just thought the back would be easy to access for another usb accessory if needed. Below are the parts I used.
Ford F-150 Lightning Wireless Phone Charging for Lariat and Below Models 6F3C628F-4B7B-4994-9E4B-7005A62BD682
FlushMount
Https://www.etsy.com/listing/887373...gallery-1-4&tr_rank=10&organic_search_click=1
【2021 Lastest】 Quick Charge 4.0 PD Type C and Qui... https://www.amazon.com/dp/B08SQCBC2...abc_R5V37C1BW65VS9EMPEVP?_encoding=UTF8&psc=1
BNTECHGO 12 Gauge Flexible 2 Conductor Parallel Silicone Wire Sp... https://www.amazon.com/dp/B08PBYLM3R/ref=cm_sw_r_sms_api_glt_fabc_M7MT5CMVS27FYWVE8PDV?psc=1
