3DogKnight
A box end wrench might be a better option over crows foot. Way stronger. If clearance around nut allows.I have a Craftsman set 1/2inch drive set that I used, had them for a long time, so I don't know if they are are extra deep, or something not 'normal'. I will say I first tried my impact sockets, but that socket was not deep enough. Another option would be a crows foot.
Sorry about your head aches with the process. You will likely want to just order the shorter U-bolts anyway, as these are barely threaded enough to accomplish this job. You need to be careful to tighten them evenly otherwise you'll just bottom out the nut where the treads end. I would highly recommend a thick washer or 2 under each nut to ensure good clamp load.
