BHunted1
Sumner County TN
2021 Ford-150 Platinum Hybrid
Ugh... I'm not playing this game with the restart crap. I'm updating it over CAN right now.
How do you force it to go CAN?
iceman77
Pete
2022 Ford F-150 Platinum
You need to hit "No" when FDRS asks "Was the update successful". Then you should see options such as "Retry USB", "Retry Verification" or "Update via CAN bus".
Updating IPC via CAN would be painfully long though. Perhaps 6+ hours or so
RellIk&5
Wayne
Las Vegas, NV
2021 F150 XLT Black Widow
My IPC update via CAN took exactly 6.5 hours. I have the 8" screen.
MikeYQM
Moncton NB Canada
2021 F-150 Platinum Powerboost | 2013 BMW M3 Comp
For the restart loop, I shut off the truck, closed the door and put the key far away for 35 mins.
that worked every time.
lots of modules and relays clicking for the first few minutes but all quiet when I returned at 35 mins.
Jaug
Jason
Fargo
2021 F150 Platinum
So checking on Forscan I have a DTC on the APIM - Checksum failure. I am currently on the APIM 1.7.1 restart loop fun. Just trying to get it going. Tried literally everything, and just tried to start the install over and it did nothing. With this error in the APIM do you think doing a PMI to the APIM will fix the DTC and then I can try the APIM update again. I feel like with the error present it won't ever update. Is the PMI process easy? I can find it in FRDS just curious if this is worth doing or even not advised to do cause it may screw it up? Thanks for any help
Bob_Mac
Bob
North Carolina
2021 Ford F-150 Platinum
Cyber Security | Developer
You have a chance on screwing it up just doing the updates so does it matter? PMI is easy, you'll be tricking it into thinking you replaced the module when in fact you didn't. Just follow the prompts as if you did replace it.
Remember, you're doing this at your own risk!
tonesto7
Anthony
2021 Lariat 502A | 3.5L EB
IT Admin | Software Developer
I know what you're saying but I was already 90 minutes in and didn't feel like playing the will it won't game with the damn thing. 5-6 seemed acceptable to me :)
It's actually going pretty quick.
I started around 4:50pm today and I say I have about 1h:30m-1h:45m left (The UCDS adapter is pretty fast at writing data)
Ford F-150 Lightning ECU module programming guide using FDRS 1645573584563
MikeYQM
Moncton NB Canada
The suspense is killing me though!
MikeYQM
Moncton NB Canada
Is anyone able to see which updates are available for me?
1FTFW1ED2MFB10996
TJSparky
WA
2021 F150 XLT (302A) RockyRidge K2
Hi MikeYQM-
This what I show your truck needs as far as updates.
Ford F-150 Lightning ECU module programming guide using FDRS 27997F44-5233-4854-BD82-A3DFDDA131AE
MikeYQM
Moncton NB Canada
Thanks!
iceman77
Pete
I wonder if you UCDS adapter is causing same network scan issues as the VCX Nano device! After all its just another J2534 pass-through device. Am I correct ?
Ford F-150 Lightning ECU module programming guide using FDRS 1645578941973
tonesto7
Anthony
It is but I’ve never seen the corruption as you’ve mentioned with the VCX Nano.
