Way2qk4u2c
Yup i removed both the widget tool and the ford widget. I reinstalled the new widget tool and then the ford widget. It works now. I must have a older version of the widget tool. Back in businessSorry you are having that error. By no means am I an expert on this or involved in the widget. But, just a couple quick suggestions. Check to see that the widgettool is updated. It should be 2.0. Try removing the widget and re-adding it. If none of that works. Remove the widget, uninstall Scriptable and start from scratch. I have found that sometimes it takes a bit of finesse to get it running properly, but once it does, I haven't had further problems. Hope that helps and be sure to re-read the second sentence of this post.
