Livnitup
Sorry, here's the plus setup: https://www.opusivs.com/support/downloadsThose are the drivers for the Mongoose Pro. I have the Mongoose Plus
Yes i ran this and installed. It is during the activation stage that it says the device is not found when plugged in. It has you unplug and replug it back in in the end.Sorry, here's the plus setup: https://f.hubspotusercontent30.net/hubfs/8362832/mongooseplus_ford2_0404_0500_setup (1).exe
Keep us updated. Did you do a PMI first of the CCM module or just go right in for the software updateI don't want to jinx it, but I'm sitting in the truck with the new Mongoose plugged in and the FIRST thing I am attempting is to update the CCM.
I was holding my breath when the Block erase got to step 4 of 257.
And then there was a 5 6 7.....!!!!!!
just called Mongoose support and they confirmed it is a dead device. Sending it back and ordering a new one.Yes i ran this and installed. It is during the activation stage that it says the device is not found when plugged in. It has you unplug and replug it back in in the end.
I did not.Keep us updated. Did you do a PMI first of the CCM module or just go right in for the software update
Wow mine comes tomorrow hopefully just a one off bad onejust called Mongoose support and they confirmed it is a dead device. Sending it back and ordering a new one.
Awesome man! What other updates do you still have to do?I did not.
I was told by the gurus to just apply the failed update to the purple module.
The update went smooooth as glass and a mongoose network scan (ahhhhh is it nice to safely scan) has CCM
Received at 5PM CDT - Installed no prob. No time tonight to putz. Tomorrow is another day and hopefully dry.Bastoids keep moving the goal posts. Was suppose to be here couple times. Now between 5 & 8…. My luck it will start pouring out. Oh well.
That was the only update left that was legit. (ABS GSM)Awesome man! What other updates do you still have to do?
Thats Awesome! Thanks for the HOPE! I cant wait for mine to get here tomorrowThat was the only update left that was legit. (ABS GSM)
The next thing I tried I don't know why I thought it wouldn't make a difference.....
I had tried everything to get rid of the DTC in my IPC. Nothing ever worked. I even removed my Forscan edit for ECT/Transmission temps.
So before I unplugged from the truck I ran the PMI against it (I had done so several times with the nano)
It completed and then I ran the self test.
Not only did the DTC clear, but my AB must have had my previous Forscan edit because the PMI returned my temps!
I got a long and distinguished LIST of modules now.
Mine started showing that almost a month ago... After a large round of updates.No, mine isn't showing that. Did you get the 2.52 OTA w/GWM update since it looks like you're ready for Bluecruise?
Mine has the same date. It's like a placeholder date I believe.No idea, maybe @iceman77 or @Jesse-Infotainment has some thoughts on it. Here's something I find odd with your screen, the BC expiration is 10/9/22 and you just tried to enable it.
