jtake
- Jan 29, 2022
- California
- 2021 F150 King Ranch
So my running boards have not been working since updating the DSM. I followed the suggestion from Platinum Peasant and looked at the running board entry in the DSM using Forscan, and saw that it was disabled -- 00. I redid the entry to 01, saved it, and voila, my running boards started working again!
Great sleuthing Platinum Peasant!
My power running boards are not moving anymore either. I did the PMI as both original and new, unplugged the battery for a few hours and tried again, even tried unplugging the running boards and completely unplugging the DSM for some time and trying it all again. Nothing seems to work. When I unplugged the DSM tho, i did get a POWER RUNNING BOARD FAULT message on the IPC. Goes away once you plug it back in. I think side loading firmware is the only solution at this point as @Jesse-Infotainment mentioned. That or go play dumb at your local dealer, something I don't really wanna do.
EDIT: I got them back alive! I went into Forscan, DSM module, went to line 744-23-02 and changed **xx-xxxx to 00 (configured them to NOT present). Saved the changes. Then went and changed it back to 01 (as built) and saved it. They came back alive instantly!
