F150 Lightning FORscan thread
cvalue13
Austin, Texas
‘22 Lightning ER Lariat
Fun-Employed
FlasherZ
St. Louis Metro
Hey @vandy1981, I did some more experimenting tonight and found the working glare-free settings from scratch.
See https://www.f150lightningforum.com/forum/threads/lightning-forscan-hcm-spreadsheet.11807/post-248344 for the post.
Here is the proper HCM recipe for a new truck:
734-01-02 xxxx x2xx xx-- (CAF ADB_GfHB)
734-03-02 xxxx xxxx x1-- (ADBDBL ADB/DBL Combined)
734-11-01 0735 89
Then you have to check to make sure there aren't any checksum DTC's set for the HCM - that will prevent glare-free and bendy beams from working.
Whammy Bar
1971 F100 + 2022⚡Lariat ER
Dumb question - can I just ask my dealer to enable a bunch of these? At least the legal ones...honk on exit, frunk beep on open, auto folding mirrors, etc.
Or are they gonna have no idea what the hell to do?
vandy1981
vandy1981
Tennessee
Plumber
734-11-01 0735 89
Thanks! I updated the OP with these changes.
merek
Buffalo, NY
F150 Lightning Lariat ER [6/20]
Anyone find a way to make the non-platinum trims make vroom vroom sounds? Surely at least the Lariat can do that?
vandy1981
vandy1981
Tennessee
Plumber
Not yet. I can make the activation button show up on the infotainment but it's non-functional.
Has anyone figured out auto tilt for the mirrors when in reverse? Looking through the ICE thread a couple people experimented, but no solution.
Anyone tried cameras at speed with the info from the ICE trucks? I have not tried these yet, but this is from the spreadsheet.
Enable Cameras at Speed - On ICE job1 '2021 Trucks this enables hitch view and bed camera in motion
Edit - deleted code as they aren't needed for Camera At Speed and caused problems with my One Pedal Drive Option.
vandy1981
vandy1981
Tennessee
Plumber
IPMA 706-02-02 xxxB CExx xx--
APIM 7D0-01-01 xxxx xxxx Fx--
APIM 7D0-01-04 xxxx EDxx xx--
You should be able to use the bed and tailgate cameras while in motion by default. I didn't have to change any settings to do this.
This is interesting - I would have sworn over the weekend when I had the tailgate down and some stuff in the back that the cameras would not stay on at speed (maybe because the tailgate was down?). This is a Lariat ER. To say the least I modified those 3 lines and tested at lunch - I now get the two rear cameras/three views on at speed.
For reference last night I made the mods for:
  • Glare Free - test drive last night shows lights still move for cornering, but in town I could never get anything else from them
  • DRL / Lightbar to 100% - Cloudy day today - sitting in front of a store front glass I could tell it was on, but not as bright as I thought it would be
  • Lane change blinks changed to 5 - works as described
  • Cameras at speed - Works for back cameras, but reported it may have worked before, I don't think mine did.
greenne
Nathan
Niskayuna, NY
When you said around town...was that because the speed was below a minimum speed for adaptive/automatic high beams? (usually 20-30mph)
OR
was it because of street lights.
How did they work at highway speeds? Did they bend AND adapt? Is glare free working for you outside of town?
OR
I believe it to be both. It was wet and rainy here last night so even street lights were reflecting making it bright for nighttime. I made it up to about 50 on a main road, but no changes from them other than bending for corners.
I get the Green A and have the option in Sync. I would say is all I have is low beams out of them for now. I anticipated you got full beams out of them all the time with the blocking for oncoming cars. Lower speeds and more light they just seem to be in low beam only.
Brandonhatch
Orange County
Anyone willing to walk me through how to use this tool? Would love to get the code to do some of these mods.
FlasherZ
St. Louis Metro
Interesting that you all see a green A. I only see a white one:
Ford F-150 Lightning F150 Lightning FORscan thread 20220825_074659
The beam-forming is working, I can see it when I'm driving at night. Perhaps I need to recheck my other modules again.
