This is addressed in the highlighted paragraph of the federal standard:
https://www.federalregister.gov/d/01-20831/p-193
There's a possibility in this case that the action had been initiated while the truck was stopped waiting for traffic and/or moving under 3km/hr
Seems there are gaps in the logic of what is allowed to happen under various conditions.
The Frunk in this case was just loaded with cargo, then closed, the load shifted while still stopped triggering the emergency escape, the FUNK AJAR Lamp should prevent the drive selector from moving out of PARK.
If the vehicle is in gear and moving, the secondary latch should hold the frunk from opening fully until the vehicle comes to a stop and placed in park or neutral.
Amps
Bolt
Similar–but obviously unrelated–to the logic gap that seemingly allows speed limit signs to use a singular reference from camera OCR input to determine ADAS speeds.
sotek2345
Engineering Manager
Thanks for sharing all. Fixing this just added something to my "do right away" list.
VTbuckeye
Vermont
Ford, please make a cover for this or make it a pull release...like a hood release so that it does not open while driving or at minimum make sure the secondary latch works EVERY TIME. I understand the need to allow escape from the confined space, but if someone happens to be trapped, blinding the driver is VERY NOT SAFE. Blinding the driver will lead to large brake application which will be very not safe for whatever is no longer in the frunk.
IdeaOfTheDayCom
Joe
Staten Island, NY
IdeaOfTheDay.Com
Software Developer
I get the need to analyze this, but it isn’t the first time it’s been documented as happening (https://www.f150lightningforum.com/...frunk-release-activated-on-the-highway.11107/) and won’t be the last. IMHO, it is an occurrence that Ford didn’t anticipate given the hard plastic raised ring designed around the button that they probably thought would protect it from such activations.
Well, I’d say a re-engineered solution is warranted🤔
The funny thing is they literally tried to reinvent something that has been around for REAR trunks for decades. The solution there was something that can be PULLED, not pushed.
There are a ton on things that can accidentally PUSH that button like luggage and the standard test for trunk size, which is fitting two golf bags. When you think of it, just about anything tall enough to reach that button could potentially push it.
IdeaOfTheDayCom
Joe
Staten Island, NY
IdeaOfTheDay.Com
Software Developer
This happened to me twice on Saturday with my golf clubs. I kind of pushed it closed, then pressed the button a bunch of times until it opened.
The button placement just seems bad.
This picture says 1000 words and I'm assuming there will be some sort of recall to put a cover there... just like the power jacks. Other than that it would need to be something twisted or pulled, not pushed.
VTbuckeye
Vermont
Do any cars have a hood release that is a little push button? Every car/truck that I have been in had a pull handle. There is a reason for this... (Oops, my leg/knee bumped the button and now my hood has to be peeled off my windshield). I think my first car had a frozen secondary latch and the primary was the only thing holding the hood shut. My 19 year old self did not see a problem with a Honda Civic that might blind the driver at 65mph with an inadvertent pull of a handle. Thank goodness it was not a push button.
FlasherZ
St. Louis Metro
What year Civic? My first car was a '79 Honda Accord, with hood hinge on the front. Didn't have to worry about that.
Ruination
2012 F150 EcoBoost
Chemist
Yikes, you almost definitely bent something. Not ideal.
VTbuckeye
Vermont
91 civic LX sedan 5spd manual 4 door. White with rust (Vermont car...) around the rear wheels and rear corners of the rocker panels. My next car was a 94 4 door Acura Integra 5 speed. (My post high school and college cars undergrad and pharmacy school). Mitsubishi eclipse 5 speed for 6 months (that car burned oil after sitting for more than a few hours). 07 saab 93 sedan was my first car with more than adequate power. It was such a comfortable highway cruiser 4th gear out of 6 was a lower gear than 5th in the Honda products. I could keep going...
jazzmanmonty
Lincoln Corsair
self employeed
@Ford Motor Company needs to send out button covers to customers immediately. Make them clear with a flip-up style latch.
OR, send an OTA update that disables the buttons while driving. Make the button so it's only usable while in park or when the truck is shut off.
Last thing i need to happen while driving with the kids is this.
