Is the Mobile Power cord worth the $500 they are now charging?
jefro
F150, Corvette, Bolt EV,
I'd also look to used market. Plenty of nice Tesla chargers out there. Just add adapter.
GarageMahal
JT
Data Wrangler
This shows in Ford's material that the charger was included, wonder who yo contact regarding that. Don't get me wrong...I'm extremely grateful for the price match for us extenders, but curious if the consider that part of this?
I decided to order it figuring there was a better chance that they would include it for free vs. give me a credit for something I didn't get. Its not worth the $500 but I won't feel too bad if I end paying for it.
rdr854
Northern Virginia
I have it and use it when inconvenient to go to a neighborhood Level 2 charger. I do not have access to a 249 volt outlet, so I am stuck with a 110/120 volt outlet.
In 13.25 hours, I have added 33 miles.
jefro
If I were to order a Gen 3 charger (maybe 2) online auction then I'd select the one that shipped with the adapter that I needed. If I were buying auction stuff I'd think they also have cheaper adapters if needed.
There must be 1000 Tesla chargers online. Guess that is why Tesla stopped offering as standard.
You're adding kWh, not miles. In an hour, you'll add about 1 - 1.1 kWh.
13.25 x 1.1 = 14.85kWh
33/14.85 = 3.3 miles. Looks right on for warm weather charging and usage.
rdr854
Northern Virginia
I understand that I am adding electricity or kilowatt hours. But my Ford Pass app still said I added 33 miles of range after 13+ hours of charging. And quite frankly, for me, I want to know how far I can drive. Thus, for me the additional range (or percentage of battery capacity) is what matters.
BennyTheBeaver
BennyTheBeaver
The Tesla mobile charger is attractive, but the price of those adapters makes it much less so. It's going to be close to $500 once you add on the adapter. I'm better off getting a 40amp 15-40 Charger. Anyone have recommendations? Amazon is flooded with different products.
Also, is wifi on the charger worth it? Or should I control all charge settings thru the truck? (Basically is it better to automate charging and settings via charger app or via truck)
Roy2001
Sacramento, CA
Tesla MX LR; Prius Prime
120v outlet could charge 1.3kWh to my experience based on Telsa and Prius Prime.
Roy2001
Sacramento, CA
Unless you must buy a 48A adapter. 30A version is cheaper.
Not with the Ford Mobile Charger it won't, at least based on everything I have read and experienced.
BennyTheBeaver
BennyTheBeaver
I'm using a 14-50 outlet so 40amp max, I would rather 40amp than a lower amp. I think someone mentioned it's roughly a 25% speed increase over the 30amp. Speed at home is a little bit if a bigger deal as my truck, at times, is only parked at home from 11pm-6am. Should still be fine most days...but I have the amperage and would prefer to maximize it.
monsterlag
AJ
Albany
F150 Lightning, Tesla Model Y Performance
I can tell you the truck charge settings are terrible and unintuitive. You have to save a location specifically and set a charge limit for that location.
vbaker4444
Vic
2021 Mach E Select AWD
I got it free with my Pro so it’s fine, but I wouldn’t pay $500 for it. Go on Amazon or eBay and order a mobile 40amp charger for a few hundred and enjoy faster charge times for less money.
Roy2001
Sacramento, CA
If you can only charge 11pm-6am and drive a lot, 48A makes more sense, or probably 80A.
