Charge Station Pro Problems
ChrisCon
The Hamptons, NY
Finally linked my Pro to Ford Pass but am getting error message about overheating. Running software 2.112.64.o.o.o. Does the software update just download some random night or is there something I have to download and install?
Glad you got it up and running. Give it a week and the update will just happen
bg226
bg226
Bryan
Anaheim
Well the overheating problems are back again. Same exact issues as before with the constant stopping and restarting with a barrage of alerts from the app saying something went wrong with the charger. I'm in contact with a Customer Experience Specialist at Ford, so we'll see what happens.
Ford F-150 Lightning Charge Station Pro Problems Screenshot_20220920-234652_FordPass
Ford F-150 Lightning Charge Station Pro Problems Screenshot_20220920-234733_FordPass
Ford F-150 Lightning Charge Station Pro Problems Screenshot_20220920-234749_FordPass
Ford F-150 Lightning Charge Station Pro Problems Screenshot_20220920-235052_FordPass
Ford F-150 Lightning Charge Station Pro Problems Screenshot_20220920-235127_FordPass
SteelTerp87
Chad
2017 F150 Lariat 2.7L (Platinum Lightning on Order
Self-Employed
My electrician ran #3 thhn wire today (good for 105AMPS and its on a 100AMP circuit). They connected the charger, it was on, I was excited! I even got the charger to connect to my network and through the app without issue. I have the Netgear Orbi mesh network so I was a little worried I would run into the same issue others have. Plugged the truck in and got excited when at 2 hours I had added over 80 miles! Then came the dreaded "Overheat" error. It's back to charging again but it appears I'm in the same boat as everyone else. Merely waiting for the firmware update to come to the unit in a few days. Not sure why we can't simply check for updates on this thing but oh well!
Firestop
Firestop
Hang in there for the update….it could take a week…and, it has worked for me for the last month..Example: My charging session from 36 to 90% completed yesterday evening…unplugged this morning with no issues or errors…..
Ford F-150 Lightning Charge Station Pro Problems D1372518-607F-4D9C-842D-158D412DD2AB
SteelTerp87
Chad
Self-Employed
I fail to understand how there’s not a “check for update” button or “update firmware” check
bg226
bg226
Bryan
Anaheim
Mine was working fine after the update, but since the last week the issues are back.
Firestop
Firestop
Yep, thought the same…..but, software development doesn’t appear to be in Ford’s wheelhouse…..yet…..
Labs4Lightning
C
Mine update to .68 worked great.
Labor Day drove hard 80+mph for 1.5 hours battery down to 18%. hot (87°) and humid charged no problem.
@Ford Motor Company
last week coolest night since installing charge station got the “something went wrong” message 4 or 5 times.
next charge, no errors.
haven’t been charging as frequently for past 2 weeks, so not able to see how frequent problem is occurimg.
*** insights worked on night with error messages, no insights on next charge. ***
Ffxdude
22 Lightning
So I set the max charge current to 60a in the ford pass app after I had the FCPS installed and received the overheating message. I was awaiting the upgrade from the .64 to .68. My software upgraded to .70 the other night, so I went back in to try and reset the max to 80a but it won’t let me.
Anyone else encounter this?
Ford F-150 Lightning Charge Station Pro Problems E1D05C22-CF1E-44C8-A974-77C19D773E6D
LightningMcqueen
Justin
Austin,tx
2017 F150, 2021 Bronco Sport
Try cycling power on charger
bg226
bg226
Bryan
Anaheim
Farmford42
WA
69 Bronco
Farmer
For the folks who got the charge station pro did it come from sun run if you just get it sent? Waiting on a shipment notification now. Also beyond the heat issues any other install thoughts for those of us as out to install?
Yes, I had it shipped direct to address of record (home), the return address on the shipping label was Sunrun location in California
Drillerr
Darin
Utah
2019 Ram Limited
I don't have the "70" update yet, but maybe it will address the issue of the charger not knowing what time it is. I have it set to start charging at 9:00pm at home, but about once every five charge sessions it doesn't start. If I unplug the charger and plug it in again it starts to charge immediately.
