Drive modes comparison -- what does each one do?
Galaxidan
Dan
30 Model A,
I would love to know what the different drive modes actually do. Please enlighten me.
I use my lightning for towing 90% of it's miles. So obviously you would think tow mode would be the choice. But why? Other then shutting off the one pedal drive and blind spot system does it actually change anything?
I noticed that the off road setting engaged the rear locking diff and I think it disables traction control?
All clearly explained in the manual, starting on page 294.
Ford F-150 Lightning Drive modes comparison -- what does each one do? drive mode 1.PNG
Ford F-150 Lightning Drive modes comparison -- what does each one do? drive mode 2.PNG
Whammy Bar
I see all that, but like... I kinda want a more technical answer.
For example... Normal vs Sport:
More accelerator pedal responsiveness... How much more? What changed in the mapping?
Stronger deceleration... How much stronger?
How is the traction setting altered?
etc...
Good luck with that.
I think the drive modes are basically the difference in how the regeneration takes places, such as hardly any in Normal mode, much more in Sport mode, even more in Tow mode, etc. I drive quite a bit in Sport mode when in city traffic, because, unlike One-Pedal mode, it is not NEARLY as dramatic and I don't necessarily want to come to a full stop every time I lift the pedal, maybe I just want to slow my momentum.
Even when Towing, I don't use TOW MODE>.... I don't really see it's value. It's certainly not doing anything 'special' just because you are towing. It's also not engaging the Max Tow additional cooling since that is always in play, regardless.
OffRoad mode is different. It is supposing that you are going in 'slow mode', and the pedal may take more pressure to get it 'up to speed', etc. And, while it may automatically engage the fixed Differential, you can also disengage that.
LightningShow
MA
'22 Lariat ER
Product Development
I tried sport mode once and didn’t like the extra regen that’s built into it. I don’t understand what is “sporty” about extra regen. I can’t say that i noticed more aggressive throttle mapping but i only used it for about 90 seconds until i got annoyed by the regen. Otherwise i’ve only used Normal.
queuewho
Western PA
22 F150 Lightning Lariat SR
Seems like offroad is a pretty good driving mode for very snowy conditions as well. You want real brakes in snow so the ABS is active.
FordLightningMan
Upstate New York
F150
Sport mode definitely feels like it has more zip. I typically turn it on when I show people what the truck can do from a dead stop. I should bring out my draggy and see what kind of quantified acceleration difference is made.
Unlike my Model 3 Performance, I don't love launching the truck. The sound the tires makes, it feels like I'll need to change them very soon if I launch too much.
LightningShow
MA
'22 Lariat ER
Product Development
My stock tires will last at least until i need to put my winter tires on, so I'm OK with that. 😄
sotek2345
Engineering Manager
I am exactly the opposite. I would like more regen than I Can get in sport mode and 1PD. I would use Sport mode exclusively, if the truck would just stay there and not make me reconfirm it every time I get in!!! I usually miss the OK button since I am backing out of my driveway when I start off so I typically just drive in normal / 1PD.
Galaxidan
Dan
30 Model A,
It would be awesome if there was some drop down menus to setup each mode individually allowing one to adjust what comes on or off and maybe a slider to adjust steering effort, Regen % ect. We can always dream. Maybe allow a user nameable mode to set it up for best personal use. The people that deal with ice and snow could dial it in just right, you could set it up for best 0-60 times.
Surfnturf
Hawaii
Lightning
I like sport mode but I stopped using it because it turns off every single time I turn my vehicle off. Ford clearly did this to thoroughly annoy anyone that prefers sport mode because there are zero possible logical reasons this is necessary.
sotek2345
Engineering Manager
Yup - exactly the same there. Though I will admit I prefer the dash in normal mode (blue) vs. sport (white). I actually really like the burnt orange they use in the off road mode!
Hey another feature request - let us select the gauge colors! My 2011 GT500 had that and I loved it. Even had a special Red, White, and Blue mode (becuase 'Murica!) that I used all the time.
Tony Burgh
Tony
Western Pennsylvania
22 Lariat ER
When I start the truck after using sport mode it asks if I want sport mode again. If I don’t hit okay it defaults to normal.
sotek2345
Engineering Manager
Right, but that prompt is very easy to miss. In the morning I get in and start backing out of my driveway. By the time I am done backing out the prompt is gone.
